ROUSTABOUT
Elite Member
- Joined
- Jan 30, 2008
- Messages
- 3,186
- Location
- Luther Willis Hill, AR
- Tractor
- Pettibone, Ford, Massey Ferguson, International, JD, David Bradley, home mades
Your talking tire size. I mean overall gear ratios. There can be a lot of variance in tire size and it will work fine. I'd still never use 4x4 on any hard surface at all. Only to go straight through a wet spot. I've already replaced front gears in a guys tractor. Replaced a broke axle on another, replaced some triangle broke thing in a new Holland. There's a fella on here getting broke front end things repaired. All wheel drive you can but four wheel drive is different.But nobody makes a 26.75 or 27.25 tire.
They need to say 27 on the side and you are fine
Speed = rpm x rtr ÷ 168 x rgr. That formula will tell you. Just find your final ratios and plug the numbers in.
