Loaderman22
- Joined
- Jan 11, 2017
- Messages
- 1,063
- Location
- Hudson Valley, NY
- Tractor
- 1947 Ford 2N, 75 MF 30B, 75 Swinger Loader, 1979 Cat D3
I usually leave all the branches in the woods too, mostly to just rot, but in the late fall I will go through with the 4 wheeler and a trailer and help myself to nice dry kindling wood. I don't use a lot of it, but I do this time of the year when I might run the stove for the colder days, then let it die out now that its 60 degrees again. Once it stays 40 I run the stove nonstop for the most part. I keep these piles of branches all over, mostly in the clearing i just made from dropping a large tree.
This year I tried something I think I got from OP. On my blow downs, I just cut them at the stump and let the leaves pull all the moisture out. Surprisingly the leaves stayed green for months, but did turn brown earlier than everything else. I will see if it helped dry the logs any in the next few weeks. Most were red(black) oak so the brown leaves are still on the branches, but they lose their leaves late anyway.
This tree is presplit...
