Hockey Puck
- Joined
- Nov 12, 2021
- Messages
- 1
- Tractor
- Kioti CK2610
I have the Kioti CK2610 and wondering which weight of oil is best in the Arizona heat. Also, how many quarts does it take. I don't have my owner's manual handy.
Oil temperature is NOT just set by the thermostat. Tractors get put in numerous situations where the screens get plugged with debris and limit cooling. Then the thermostat is open and you're running on whatever cooling capacity you have left.Oil temperature is set by the coolant thermostat, which is usually about 190 F.
Last I knew, Those wild dog tractors were Water cooled, with the engine temperature controlled by a THERMOSTAT.
If the engine coolant heat exchanger is inadequate for the task due to ambient temperatures or debris fouling of the air passages, Clean the unit or add additional capacity as required.
Pure water is a better heat transfer medium than is typical coolant mixes. Add "waterwetter" for additional heat transfer.
The oil should never see "above normal temperatures" .
What is the typical thermostat opening temp these days? 90C? 195F ?
