Mangled Housing for Hydraulic Connectors 1735M
   / Mangled Housing for Hydraulic Connectors 1735M #1
pattycake
Member
Usa
MF 1735m
I caught a limb between the right rear wheel and the step, causing the step to bend and smack into the housing/shroud that holds and protect the hydraulic connectors. I managed to remove the step and "bend" the housing back enough to get home but is is banged up big time.
I have been searching for two days trying to find a picture or a part number so I can replace the housing but have stuck out. I went to the dealer today and the parts manager had the same luck as me - could not find the part.
Does anyone know what the part number is for this housing, or have a link to a parts diagram so I can look it up?
2019 MF1735M
If I could finds a parts manual that has all the diagrams, I'd be ok buying one.
   / Mangled Housing for Hydraulic Connectors 1735M #2
Agco Parts Book, Changed a bit but still accessible. Enter as guest user.
   / Mangled Housing for Hydraulic Connectors 1735M #3
Got a picture of the part you want to replace to better assist those of us that arent familiar with MF
   / Mangled Housing for Hydraulic Connectors 1735M #4
Did you look closely at the physical part to see if there a number on there? Might be something that is lightly stamped into the part. I personally don't know if there is a number on there.
Not my actual tractor but the only pic that I could find. The parts on my tractor are too mangled to see them. I will keep looking for better pics. I have searched the parts link in this thread but still cannot find an image of the parts.
THANK YOU !! Who'd have thought - Joystick Assembly !
That part #61 is one part of the housing that is bent bigtime. There is also a sheet metal part that connects to the tight hand side of Part #61, as well as a cannister holding "something" on the left. Not sure what that "something" is. Any ideas?
   / Mangled Housing for Hydraulic Connectors 1735M #8
My 1754 has a couple fuel filters behind that rear cover.
Once again, TractorByNet membets come thru with sage knowledge helping hands.
I truly appreciate the members here. Thank you, again.
   / Mangled Housing for Hydraulic Connectors 1735M #10
Been there, done that! If you haven't yet found part names/numbers, here's what you may or may not need:
FILTER BRACKET #7075525M91
FILTER COVER #7075531M91
COVER #7075454M1
And maybe;
BRACKET #7075326M91
2015 Chevrolet Malibu Sedan (A55853)
2015 Chevrolet...
2012 Club Car Precedent Electric Golf Cart (A53424)
2012 Club Car...
16FT box truck (A53422)
16FT box truck...
2008 KALMER 4X2 SPOTTER TRUCK (A54756)
2008 KALMER 4X2...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
2015 Hyundai Veloster Hatchback (A53424)
2015 Hyundai...
