Unusual Noise when glow plugs cut off
   / Unusual Noise when glow plugs cut off #1
ns_in_tex
East Texas
Kubota L4610 HSTC, International 2400, Hesston 1280,
Recently started making about a 2 second chattering noise as the glow plug lite goes off.
Kubota L4610 HSTC, 4000 hours. If we cycle the glow plug, it will do it each time.
I figure something is about to quit working.
Any help appreciated.
   / Unusual Noise when glow plugs cut off #2
Sounds as though your battery cannot keep both glow plugs and fuel solenoid going. The chattering is likely the fuel solenoid opening back up when glow plugs go off.
Your battery is probably ready to quit.
Thanks, I will do some battery checking.
   / Unusual Noise when glow plugs cut off #4
Or the soleniod(s) themselves.
   / Unusual Noise when glow plugs cut off #5
Or possibly a relay on the way out. That could chatter.
OK, we did a battery check & believe it is good. By the time we opened the hood, hoping to get closer to the noise, it was very short & we could not determine where it was coming from.
We put a battery maintainer on it. Will try to check again when cold and have the hood open. I presume this may be the only way to get the longer chatter (first engagement of glow plugs) while cold.
UNUSED LANDHONOR PHA-16-2C HYD 3PT HITCH MOUNT (A54757)
UNUSED LANDHONOR...
2008 Ford Ranger Pickup Truck (A54814)
2008 Ford Ranger...
2004 Ford F-550 Mason Dump Truck (A55788)
2004 Ford F-550...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A53421)
2018 John Deere...
(49) 2" X 2" X 98" TUBING (A54756)
(49) 2" X 2" X 98"...
43003 (A55851)
43003 (A55851)
