Safety switch
   / Safety switch #1
sg47619
Workmaster 55 New Holland
I have a Workmaster 55 New Holland, the high/low leaver won’t stay in nuteral so the tractor will start. I hace to keep moving it back and forth to get it to ingauge.
   / Safety switch #2
The hi/lo range switch on my Workmaster 60 is a known problem and likely the same issue you’re having.
Call your dealer and order two. They are about 25.00. One wire and a 17mm wrench and you’re in business.
I just clicked 500 Hrs on my 2017 model and on the third switch already.
   / Safety switch
Thanks, Sorry I haven’t been back on. Where is it located on the tractor.
   / Safety switch
Mine is a 2016 650 hour.
   / Safety switch #5
It’s at the base of the Hi/Lo lever near the transmission case. It’s got a black rubber cap over it with 2 wires coming out the end into a connector.
Unplug the wires, pull back the rubber cap and you should be able to get a wrench on it. Super easy.
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
2014 Chevrolet Cruze Sedan (A51694)
2014 Chevrolet...
JOHN DEERE 54D LOT IDENTIFIER 149 (A53084)
JOHN DEERE 54D LOT...
1838 (A51248)
1838 (A51248)
2008 FORD F550 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F550 XL...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
