Tire Pressure Gauge for Calcium Filled Tires
   / Tire Pressure Gauge for Calcium Filled Tires #1
vinicius zidal
Streamlined look
Is there a tire gauge available? That can be used with calcium filled tractor tires and lasts for more than a few uses.
   / Tire Pressure Gauge for Calcium Filled Tires #2
   / Tire Pressure Gauge for Calcium Filled Tires #3
I've been using this one from Milton for over 20 years on my calcium filled tires.
It's supposed to be corrosion proof but I rinse it off after use just in case.
Or cheaper on Amazon:
https://www.amazon.com/Milton-S-928-Water-Filled-Pencil-Pressure/dp/B0000AXBXW/ref=mp_s_a_1_4?crid=1EY7M3S8F2HOR&keywords=Milton+Tractor+Tire+Gauge+—+For+Fluid+Filled+Tires%2C+5–50+PSI%2C+Model%23+S-92&qid=1642481301&sprefix=milton+tractor+tire+gauge+for+fluid+filled+tires%2C+5+50+psi%2C+model+s-92%2Caps%2C297&sr=8-4
   / Tire Pressure Gauge for Calcium Filled Tires #4
When the tire guy came out to put fluid in my tires, he added air to the correct inflation.
I asked how to check the pressure,
He recommended measuring from the ground to the top of the wheel, with the tractor level.
I did that, and wrote the measurement on the wall in the shed.
Now, to check the pressure, I simply use a tape measure.
The "stem" does not even need to be rotated to the top,,, (y)
You will find a tape measure is more accurate than any pressure gauge,,
the tire changes height a lot when air is added.
   / Tire Pressure Gauge for Calcium Filled Tires #5
Interesting
   / Tire Pressure Gauge for Calcium Filled Tires #6
Interesting
My first ATV (1984) did not specify tire pressure, because it was only 2psi,
Instead, the manual gave a circumference of the tire.
You had to measure all the way around the tire to get the correct pressure.
Just a little air could change the circumference by three inches.
I got a VERY low pressure gauge, and measured those tires,,
that was easier, but, less accurate than the tape measure.
I lived with that,
I did not go on long rides, where the locked axle needed to have identical tires to be able to go straight.
   / Tire Pressure Gauge for Calcium Filled Tires #7
Harbor Freight air gauge. Best ever. The long line from tire to gauge can be easily purged between measurements.
   / Tire Pressure Gauge for Calcium Filled Tires #8
I used to have one similar to this one:
It worked well, but I lost it after a couple of years. By then I had learned to tell by the sound the tire made when I "thumped" it. I'm sure it was not as accurate as a pressure gauge, but it kept me close enough.
   / Tire Pressure Gauge for Calcium Filled Tires #9
I had a Milton that was suppose to be for fluid filled tires, it didn’t last. I may try one of those Harbor Freight ones.
   / Tire Pressure Gauge for Calcium Filled Tires #10
I don't recall what the brand was that I had. I had it for about 2 years before I lost it. It was still working when I lost it. It was not used frequently, and I did make a point of thoroughly rinsing it out after each use. My post was not meant to be an endorsement of the Milton brand, just showing something similar to what I had.
CFG Industry MH12R Mini Excavator (A57149)
CFG Industry MH12R...
2019 GALYEAN...
2021 Chevrolet Silverado 2500HD 4x4 Crew Cab Pickup Truck (A56858)
2021 Chevrolet...
2014 Chevy Malibu Sedan (A56859)
2014 Chevy Malibu...
WOOD GRABBER FOR MINI EXCAVATOR (A58216)
WOOD GRABBER FOR...
TANK MANIFOLD (A55745)
