Out in field with 2638 manual is no help
   / Out in field with 2638 manual is no help #1
Root Cause
North Carolina mountains
Mahindra 2638
It looks like I am low on hydraulic/tranny fluid. No eyepiece or dipstick in sight. Manual offers nothing. Anyone know where it is on 2638 or 2538?
thanks in advance.
   / Out in field with 2638 manual is no help #2
The viewing glass is above the PTO shaft on the rear of the tractor about 4-6" and slightly to the right of center.
It may not help you if your fluid is clear.
I made a homemade dipstick using a long zip tie. About 14" long. If you can find something around the area that is a little flexible you can lower it into the filling port on the top left of the rear housing, and get an idea how low it is.
Any signs of hydraulic leaks? Maybe you popped a line.
Hey, thanks for responding.
Actually, I did put in a zip tie just to see where is was but it didn't tell me much.
I did find the eyepiece and it is useless with a backhoe in the way and I still don't know if it is clear or low.
What a sad design.
I saw a couple of dark spots on the ground and knew I had a leak.
I ended up adding about 8 ounces and it started working again.
I will have to figure out what is full and then use your idea with a zip tie and mark it like a dipstick.
Thank you for that. It is a good idea.
   / Out in field with 2638 manual is no help #4
I have seen where john deere has a red dye you can out in the fluid to make it easier to see. I have had the same issue with my 2538.
Yeah, I was thinking about that and wondering if I could buy something but then would it stain the eye piece and give a false reading. This is SO stupid. I mean, how long has a dipstick been used?
I want to take care of my equipment and I think zip tie is the answer. I do need to cobble something so it can't fall inside though. :cool:
   / Out in field with 2638 manual is no help #6
Walmart sells and ships it
mt3668
   / Out in field with 2638 manual is no help #8
The use of a dipstick has been around a long time, so has the sight glass. I have not used the dye but I have also not heard or known of the dye discoloring the glass.
Here is my solution.
I have ordered the dye to get the fill correct.
I will add a dipstick because it is nearly impossible to see the sight glass with my backhoe attached.
The best I could do yesterday was put to my phone down inside the backhoe brackets and take a picture.
   / Out in field with 2638 manual is no help #10
I don't know how you will add a dipstick, I don't think you can just place one on the fill cap and get it down to where you need it and i don't think there is an opening anywhere on he side to be able to do it.
I used a 10-12" zip tie and got just a little oil on the tip.
It told me the oil was there but no way to determine if it was ok or low.
I think I can cobble together something with a washer so it doesn't fall in.
After I put in the dye and find the lower level, I will mark the zip tie. Same for when it is midways on the sight glass.
It sounds like I am making this difficult but with a backhoe, it is difficult at best. The engineers who decided this was acceptable had their heads up their......
wait, maybe isn't that hard for them.
   / Out in field with 2638 manual is no help #12
For those of you thinking of "adding a dipstick" to the 2538/2638 fill hole, I would recommend against it.
I use a 14" long zip tie "as a dipstick" after I remove the filler cap on top of the housing. I have it marked within an inch of where the sight glass is. If I fill it a little full, that's better than not enough. Another quart in the reservoir over the dot on the sight glass, won't be detrimental to the equipment.
Once I check the fluid level, I put the "dipstick" away and replace the filler cap.
I'm going to buy the dye as well.
Agree 100%. I will keep the original cap on as well.
I am going to cobble together a zip tie and a plastic washer or cap bigger than the opening so I don't drop the zip tie into the tank. That would be me!
   / Out in field with 2638 manual is no help #14
Root Cuase and duffer, I made some posts in the RK forums a few months back about the same issue with not being able to see the fluid level with the sight glass. The dye does work great and doesn't effect the glass at all. One bottle treats 5 gallons of trans oil. Others on here lead me to the JD oil that I found on eBay for something like $12.50 a bottle. I had overfilled mine due to not seeing it in the glass. After adding the dye I drove around for a few minutes to mix it up and walla, what a beautiful red color. I used a siphon pump to remove the access and get it to the top of the glass. I did notice the other day that with the front end loader and 3 point lowered the level is at the very top of the sight glass but with both raised the level drops below the glass where you can't see it. Keep that in mind when servicing yours.
   / Out in field with 2638 manual is no help #15
Use the tie wrap to attach to a 2" long piece of something. It can be a dowel rod or another tie wrap. Make a tee at the end of the tie wrap and it won't fall in.
   / Out in field with 2638 manual is no help #16
And whatever you do, don't forget to put the filler cap back on. It's VERY pricey. (ask me how I know)
Thanks, everyone for the ideas and information. I can't return the favors you have done here but I am taking pictures and building a maintenance file for those who follow later on.
   / Out in field with 2638 manual is no help #18
My Kubota HAS a dipstick. Sometime, under shaded lighting, the level on the dipstick is difficult to see. I improved this situation. Took the cap/dipstick into the shop and roughed up the end of the dipstick with a file. Now it's an easy read.
Good idea. I will do that for sure.
I know I made a big deal with this but the manufacturer needs to do better. Having oil and being able to read the level is critical for pete's sake.
Getting down on my knees in the mud and looking at a dime-sized sight glass from 3 feet away in hopes of seeing a thin line of clear oil is just dumb.
Toyota has many lean ideologies that made them a quality manufacturer. Gemba is a term that directs a leader to get out of the office and get into the real world.
I guess Indians don't speak Japanese. Meanwhile, they are dragging me down to their level with a homemade dipstick. I will get off my soapbox now and be grateful that I have a trac-hoe instead of a shovel and a wheelbarrow.
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
FUEL CELL (A58214)
FUEL CELL (A58214)
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2019 CATERPILLAR 246D3 SKID STEER (A60429)
2019 CATERPILLAR...
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
1969 VOLKSWAGEN BUG (A59905)
1969 VOLKSWAGEN...
