Castrol 0w40 a3/b4 for tractor?
   / Castrol 0w40 a3/b4 for tractor? #11
I just figured it was not appropriate for use in a diesel, let alone a tractor diesel. I started to rethink that and decided to ask to make sure.
I looked at the product data sheet and it is rated as API CF for diesel engines and API SN for gasoline engines, and ACEA A3/B4 for passenger car gasoline and diesel engines. Now, CF is an old spec for diesel engines introduced in 1994 and the current spec is CF-4. According to the American Petroleum Institute, who develops those ratings, they state that CF oil generally is not appropriate for a 2009 and later engine. However SN is a current spec for gasoline engine oil. ACEA ratings aren't as often used in the US but an oil designed for a heavy-duty diesel engine gets an "E" rating like E6 or E9, which this oil lacks.
I tried to look for a manual for the Branson online and couldn't find anything, so I can't tell you exactly what it requires. My tractor of a different brand than yours was made the same year as yours and it states an API CJ-4, CK-4, or ACEA E6 or E9 oil must be used. I suspect this Castrol oil is probably a gasoline engine oil that meets some older and lighter-duty specs for diesel oils. I would NOT use this in your tractor unless you see in your manual that an API CF or ACEA A3/B4 oil is specifically acceptable.
I looked that up too.
Owners manual says nothing about it but the service manual says CG. CG is a higher rating than CF. CG is for engines meeting 1994 emission standards. CF is 1990.
As I started researching this more it became clear the main difference between these standards is emissions and how they can effect exhaust emissions parts.
The Branson has a passive DPF. It relies on maintaining a high heat continuously to clean itself out.
So no, Castrol is not an appropriate oil. Heck, a CG rated oil really isn’t the best either.
The soot caused by the oil will likely cause issues and eventually ruin the dpf (or def if you have that).
However, I will eventually remove the DPF off of my tractor and replace it with a simple muffler. Right now I am not having a problem with it and it can stay.
By the way, the Branson does not have a computer so it could care less if the DPF was still on. It will likely have more horsepower too.
   / Castrol 0w40 a3/b4 for tractor? #13
The CJ-4 spec was introduced to limit the amount of sulfated ash, phosphorus, and sulfur (collectively, referred to as "SAPS") to avoid clogging up EGR and DPF/DOC systems. Previous specs such as CI-4 are not necessarily low-SAPS formulations, they may not meet current wear specs, or have some other component that is "out of spec" compared to current specs.
1840 (A51248)
1840 (A51248)
2008 CPS END DUMP (A53843)
2008 CPS END DUMP...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
BENNU HYD SCAFFOLDING SYSTEM (A52706)
BENNU HYD...
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
1996 INTERNATIONAL 4700 4X2 DUMP TRUCK (A51406)
1996 INTERNATIONAL...
