New alternator and new regulator charging at 17.5 V
   / New alternator and new regulator charging at 17.5 V #1
Jerry/MT
Elite Member
North Idaho-The Palouse
New Holland TD95D, Ford 4610 & Kubota M4500
My alternator warning light came on a couple of weeks ago. I checked the base battery voltage (engine off 12.5V) and then started the tractor and measured the voltage (12.5 V). I replaced the factory alternator on my '82 Ford 4610 and decided to replace the voltage regulator also. I installed the new voltage regulator on the new alternator and ran the same voltage check. Engine off I got 12.5V and engine running I got 17.5 V. The voltage regulator was supposedly adjustable but when I tried adjusting it, it stayed at 17.5 V. I suspect the voltage regulator is bad It is a Transpo M5-152A, the same as the one that was on my old alternator and the regulated voltage should be 14.2V. When installed originally, the old alternator ran at 14.2 V with old voltage regulator.
Is there any reason that the new alternator would not be regulated to 14.2 V ?
   / New alternator and new regulator charging at 17.5 V #2
When a regulator is bad it doesn't regulate. Alternator will put out 17.5 volts without a regulator to regulate it.
   / New alternator and new regulator charging at 17.5 V #3
Either your wiring is messed up and lacks a ground reference, you left out a wire somewhere, or the regulator is defective. You could even try your old regulator on the new alternator just for comparison.
I did that and got the same result. The field wire connection tab is loose so I am thinking it was damaged in shipping. I checked the grounds and they were good. I checked the resistance of the battery to alternator connection un-hooked at it was less than 0.1 ohms.
Yeah if the regulator fails it goes to full field. I put a new regulator on a new alternator and it runs at 17.5 V,. I put the old VR on the new alternator with the same effect. That's why I am suspecting the alternator.
Thanks for all the help. I sent the alternator back to Amazon.
2014 Cummins ISL 320HP 8.9L 6-Cylinder Turbo Diesel Engine (A55852)
2014 Cummins ISL...
2019 Chevrolet Silverado 2500 4x4 Warner Service Truck (A55852)
2019 Chevrolet...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55851)
2025 Kivel 48in...
2012 Chevrolet Impala Sedan (A55853)
2012 Chevrolet...
2022 Chevrolet Tahoe FL SUV (A55853)
2022 Chevrolet...
