Wood stove top fans (heat powered)
   / Wood stove top fans (heat powered) #62
26 minutes later, shut down the full open air control and open it a couple bars.
   / Wood stove top fans (heat powered) #64
Radiant heat: energy particlues striking a solid object and transfering energy to that object.
Conduction: transfer of energy between objects in contact with each other. Always high to low.
Convection: energy being transported to other locations.
THE LOW PAY GRADE version
   / Wood stove top fans (heat powered) #65
I'm starting to understand how people get so many posts-as I call the kettle black... ;)
   / Wood stove top fans (heat powered) #67
I just started using one of these fans this year. My understanding is these use different metals, that when subjected to a heat differential, create a voltage that powers the fan (I.e. a Peltier device).
My wood stove top surface is about 20” x 30”
Question / shower thought: Where is best place to set fan on stove top? Middle, front edge (drawing hot from stove and blowing away from stove), or back edge (drawing cooler air and blowing across stove top)?
Assumption #1: Let’s assume surface top is uniform heat and fan will generate same voltage to motor no matter location.
At back edge: Does blowing cold dense air across stove move more air? But does it take more torque and fan is slower? So air volume is same? And does heated cold air now just rise and circulate the same as it would without fan?
At front edge: Fan might spin faster (as there’s less hot air resistance), and air may be pushed laterally as desired, but does fan move as much hot air?
I have one, put it at the back of the stove so it blows over the slots on the stove top surface that heat comes out of.
I like to watch it spin, fast when really hot, slow when cooler.
Don't think it moves any amount of air to speak of though (haha) will move the smoke from a match thats flaming out but not much more.
Other than the entertainment value of watching it spin and it looks "pretty".... I think I wasted $100 on mine.
   / Wood stove top fans (heat powered) #68
Same here but I bought knowing they were worthless for really moving air. I've seen some larger ones with an aircraft looking propeller move a bunch of air.
   / Wood stove top fans (heat powered) #69
   / Wood stove top fans (heat powered) #70
LOL...motion is not thermal.
All forms of energy resolve to HEAT energy as their final resting place.
In order to SLOW a moving object, It must give up heat. Even a Neutrino emitts a burst of thermal detectable energy IF it strikes an atom of scinillation prone quartz.
Adiabatic cooling of the air as it rises is example of a similar necessity based on pressure change.
Even though our understanding of the many phenomenon that surrounds us is imperfect, Boyle's Gas Laws are well described and agreed upon.
Again, Stick you hand in a hot oven, Just don't touch anything! ;-)
2017 CATERPILLAR 323FL EXCAVATOR (A51246)
2017 CATERPILLAR...
Arksen Rollable Fuel Cell (A51573)
Arksen Rollable...
FAKE (A52472)
FAKE (A52472)
2018 JLG 4045R 40FT. Electric Scissor Lift (A51691)
2018 JLG 4045R...
2006 Intellistrobe AFAD Trailer (A52377)
2006 Intellistrobe...
2018 GENIE GTH636 TELESCOPIC FORKLIFT (A51246)
2018 GENIE GTH636...
