JD 630 3PH lift capacity
   / JD 630 3PH lift capacity #11
Can you add some weights to the front like the tractor pullers use? a couple hundred pounds mounted out front 3 or 4 feet would do wonders ,--kinda in the way but IF it does the job,---- might be worth trying.
   / JD 630 3PH lift capacity #12
In post #9 the OP says that 260 gallons of water is pretty near to balancing the 3pt load versus the tractor weight.
Since it's in equilibrium with 260 galons in the tote, summing the moments around the rear axle will enable him to find the apparent weight on the front end.
Then he can redo the calculation to adjust for the 60 gallons removed. That will give the new downforce on the front just the same as adding that much weight.
rScotty
2014 CAT  299D TRACKED SKID STEER (A53843)
2014 CAT 299D...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
ALLIANCE 15' HEAD CARRIER (A51247)
ALLIANCE 15' HEAD...
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
2019 FREIGHTLINER M2 26' BOX TRUCK (A51247)
2019 FREIGHTLINER...
UNUSED LANDHONOR LHR-PC90 HEAVY DUTY PLATE COMPACT (A51248)
UNUSED LANDHONOR...
