Kubota L4200 4wd ring and pinion front axle
   / Kubota L4200 4wd ring and pinion front axle #1
thadgray
Fayetteville, TN
Kubota L4200
This will be my 2nd set of gears installed and was wondering if they look aligned correctly? Gets expensive replacing them.
Any information would be greatly appreciated.
Thanks
Thad
   / Kubota L4200 4wd ring and pinion front axle #2
Looking for some advice. I think I have the same problem with my Kubota L4200. How difficult of a fix was this? Got a wild guess on your total parts cost?
   / Kubota L4200 4wd ring and pinion front axle #3
That photo shows a fair bit of damage to the gears. Not sure about the bearings, they may be alright but depending on price may be worth changing since you're in there anyways.
Not sure if your problem is the same. Messicks website is a good resource for parts and diagrams. Here is a link to their site. Just hover over the "online parts" tab and then click on Kubota from the pop up. Type in you model and then click parts catalogue, then front axle and wheel... then front differential and all the parts are listed with prices further down.
Hope this helps!!
Galvanized Livestock Gates - (6x Total Gates) (A55218)
Galvanized...
UNUSED KIVEL 3500# PALLET FORKS (A54757)
UNUSED KIVEL 3500#...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
2019 CATERPILALR 315FL CR EXCAVATOR (A52705)
2019 CATERPILALR...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
