Tracked vs tires on Mahindra?
   / Tracked vs tires on Mahindra? #1
antryan
Can-am
Hi,
Does anyone know if there is a track that might fit a Mahindra 85P? I'm assuming a third party might manufacture a track kit that might fit but I haven't found any online.
Would a tracked or quadtrac type system assist with towing on 25/30 percent steep slopes?
   / Tracked vs tires on Mahindra? #2
Mahindra mPower 85P​
Dimensions
Length:165.9 inches
421 cm
Width:81.4 inches
206 cm
Height (cab):108.2 inches
274 cm
Weight:8177 lbs
3709 kg
Mahindra ML285 Loader
Loader weight:2090 lbs
948 kg
Mechanical
Chassis:4x4 MFWD 4WD
Steering:hydrostatic power
Brakes:wet disc
Transmission:12-speed synchro shuttle
   / Tracked vs tires on Mahindra? #3
   / Tracked vs tires on Mahindra? #4
Hi,
Does anyone know if there is a track that might fit a Mahindra 85P? I'm assuming a third party might manufacture track kit that might fit but I haven't gotten any seen any online.
Nice to have you on TBN with us antryan. Have you checked Soucy for a pod kit? Tracks will give you better tractor but also raise your tractor and its center of gravity a bit. Sorry I can't give you more info than that.
   / Tracked vs tires on Mahindra? #5
I don’t think a 85P has enough butt to roll tracks and a heavy 3 pt attachment.
2017 Ford Transit 350 (A57148)
2017 Ford Transit...
2015 Ford Transit Connect XL Cargo Van (A56858)
2015 Ford Transit...
2127 (A58376)
2127 (A58376)
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
International DT466 Fuel Truck (A55272)
International...
2007 FREIGHTLINER COLUMBIA 120 (A58214)
2007 FREIGHTLINER...
