Advice On Mowing 10 Acres (X 2) to 1.5-2 Inches. Finish Mower?
   / Advice On Mowing 10 Acres (X 2) to 1.5-2 Inches. Finish Mower? #1
wirlybird
Gold Member
Oklahoma
John Deere 3038 E, John Deere 3032E, John Deere 756, John Deere X585, John Deere 332
Hi all,
Hope this falls into "attachments"!
A customer has two 10 acre fileds that are used as polo practice fields. Last year I kept one cut with my 756 JD W/60 inch deck cutting to 1.5 inch height. The other was leveled and is regrowing.
I am wondering what might be a better solution for this. Read this as "economical" solution!!
I do have a Muratori 6 foot finish mower but have not tried it yet. Not even sure if I can get a cut as short as 1.5 to 2 inches.
I have considered tow behind reel mowers but not sure how well that would work. As you can imagine these fields are not "fairway" smooth! Even though they quite good and are very flat.
Thanks for any general thoughts or advice on possible attachments.
   / Advice On Mowing 10 Acres (X 2) to 1.5-2 Inches. Finish Mower? #2
As you specify the 20 acres are very flat, consider a Flail Mower with the correct hammers for grass.
I have a Muratori 6 foot finish mower but have not tried it yet. Not even sure if I can get a cut as short as 1.5 to 2 inches.
Any Finish Mower should cut to 1.5" with the correct bushings installed to establish the cutting height.
Thanks. I have a John Deere 25A I rebuilt. It cuts a field nice but haven't tried it down to 1.5 inches.
Definitely worth trying out though.
I am going to dig the finish mower out tomorrow and see how low it will adjust to. The manual is no help on that! It just says, "use shims to adjust height to where you like it"!!
   / Advice On Mowing 10 Acres (X 2) to 1.5-2 Inches. Finish Mower? #4
Similar thread:
   / Advice On Mowing 10 Acres (X 2) to 1.5-2 Inches. Finish Mower? #5
This idea might make your job a little quicker/easier. I have done this with one tag along and a 42 inch mower on Wheel Horse. The set up worked very nicely.
For the money and the straight lines I would use a tractor instead of a z-turn.
   / Advice On Mowing 10 Acres (X 2) to 1.5-2 Inches. Finish Mower? #6
You might look into a roller or chain link drag to minimize the divots before you mow. The clumps of dirt will be hard on any mower.
Thanks. That is one thing that is being taken care of. The divots are being replaced or put back in the ground!
I guess it's one of the things the "student" riders have to do at the end of a session.
Also make sure all polo balls are collected!
   / Advice On Mowing 10 Acres (X 2) to 1.5-2 Inches. Finish Mower? #8
I mow a sloped and irregularly shaped 7 acre field with an 84" Landpride 3 blade 3pt mower. It works well behind my L6060 Kubota but it takes 3.5 hours due to the slope & shape. Lately, I've been looking at 12' batwing mowers to speed up the process. They're expensive and hard to find right now though.
If time is of no concern, IMO, almost any finish mower will cut your field to 1.5" with no problem.
Thanks. I'll be trying out the finish mower today to see how it goes.
   / Advice On Mowing 10 Acres (X 2) to 1.5-2 Inches. Finish Mower? #10
Yep. Flail mower is the way to go.
2010 HEIL TOKEN TRAILER (A52472)
2010 HEIL TOKEN...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
2012 Ram 3500 Chassis Pickup Truck, VIN # 3C7WDTAL9CG134341 (A51572)
2012 Ram 3500...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
New Long Forks (A53002)
New Long Forks...
Cat TH407C Telehandler (A52748)
Cat TH407C...
