Now I spilled my hydro oil I gotta fill it up
   / Now I spilled my hydro oil I gotta fill it up #1
Raul-02
the armpit of the entire universe New Jersey
kioti DK4710 SE HST CAB
Hydro oil got expensive while I wasn't looking
Amway the fill port on the kioti is bid enough but not easy to pour into.
Any tricks you got?
I'm thinking of turning a threaded poly insert to screw in that'll accept a length of tubing and a funnel.
   / Now I spilled my hydro oil I gotta fill it up #2
I pour the fluid into one of those pour cans with a spout first, then use whatever funnel I have that fits best into the fill hole. Then pour a little bit, check the level, pour some more, repeat.....
   / Now I spilled my hydro oil I gotta fill it up #3
I use a hand pump that drops the pickup end right through the top of the 5 gallon bucket, and hand pump it right into the spout. The outlet spout on the hand pump fits directly into my fill tube.
   / Now I spilled my hydro oil I gotta fill it up #4
I've only changed my 4105's hydraulic oil once (at the 400hr. mark).
I did it 'old school', I guess. From the container into a graduated measured (5 litre) container, and then using a wide-mouth funnel, into the reservoir.
Yes, it took time and patience, but the job was done with no mess and accurately.
   / Now I spilled my hydro oil I gotta fill it up #5
Me too. A "bucket pump". Works great though it can be slow to pump the entire 9 gallons for a fluid change. I'd rather be slow than make a mess or overfill the tractor.
Tip: don't leave it in a half filled bucket of oil, especially in a building that gets damp like my barn. It does not seal the bucket. I ended up with water in the oil. Now I park it in an empty bucket and seal the half full bucket up with the plastic lid.
   / Now I spilled my hydro oil I gotta fill it up #6
I siphon it from the 5 gallon. Slow but never spill.
Best,
ed
   / Now I spilled my hydro oil I gotta fill it up #7
I use a 1 gallon oil can with a valve, similar to this one. A little time consuming, but easy and clean.
   / Now I spilled my hydro oil I gotta fill it up #10
Like many above I use a simple & cheap (HF - $6.99) hand pump... slow but no mess, & if you accidently overfill the tractor you can pump some fluid out...
2008 CAT D6T DOZER (A58216)
2008 CAT D6T DOZER...
LOT: (1) Steel Plate Sheet, 1/4" Thick, 48" x 96", (1) Steel Plate Sheet, 1/4" Thick, 41" x 96" (A59076)
LOT: (1) Steel...
Giyi 72" Box Broom Sweeper (A57149)
Giyi 72" Box Broom...
2007 FORD F-150 XL TRITON (A55745)
2007 FORD F-150 XL...
2014 BMW X1 AWD SUV (A56859)
2014 BMW X1 AWD...
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
