Bolt Size of the Tie Rod for Kubota BX1800
   / Bolt Size of the Tie Rod for Kubota BX1800 #1
nosplace
What the thead size on the steering cylinder or the Tie Rod for the BX1800. I damage the threads and need to clean it up with a Tap/Die. Are they 14MM?
TIA,
Don
   / Bolt Size of the Tie Rod for Kubota BX1800 #2
I will bet they are English.
Buy the range of bolts, align them with light behind ('teeth' should 'nest'), return 'em.
Been my experience, if Metric, the C/F equivalent is a ratio (by country?) but distinct enough to eyeball over an inch or so of alignment.
   / Bolt Size of the Tie Rod for Kubota BX1800 #3
TIA,
Don
To confuse the issue more - there is a Japanese Industrial Thread. And I'll bet, that's the thread. I lost a Zerk fitting on my Kubota. Couldn't get metric or SAE to fit. Ordered one from the Kubota dealer which threaded in just fine.
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A53472)
2017 Ford F550...
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
Simpson 3400 PSI Pressure Washer (A51573)
Simpson 3400 PSI...
Electric Concrete Mixer (A51573)
Electric Concrete...
New/Unused 10ft Workbench with 15 Drawers (A51573)
New/Unused 10ft...
