Rotary Cutter Dearborn 2 disc plow parts
   / Dearborn 2 disc plow parts #11
CNH still shows a parts listing for these plows. Hopefully this link will stay active, and take you to that page...
pvassociates.net is available for purchase - Sedo.com
(Type in disc plow, in model selection box)
If you can get the actual number from the bearing and seal..., try here. Usually if you get the bearing number, they will offer the cup and bearing selection also.
JBR 17 LLC
These folks are really reasonable on their bearings and seals.. Takes about a week to get them, at least for me, here in Ohio..., but worth the wait pricewise.
Just tried that link, domain is for sale.
I guess another business has succumbed. . .
   / Dearborn 2 disc plow parts #13
Still, it sucks to lose sources. . .
   / Dearborn 2 disc plow parts #14
Just take the old ones out and get the number off them. Or take to a bearing place. Or call and order from a bearing place. Call an agri supply. You are talking about a double disc break plow I'm assuming.
   / Dearborn 2 disc plow parts #15
Yes, Double disc. I was just hoping that I could try to get the correct bearing and seals BEFORE taking everything apart and having parts laying about for an indeterminate period of time, and potentially unreadable part numbers to contend with...
   / Dearborn 2 disc plow parts #16
   / Dearborn 2 disc plow parts #17
   / Dearborn 2 disc plow parts #18
You may still be in luck. I'll assume it's a model 10-80 plow. Found the mosel number doing a search for Dearborn disc plows.
Searched CNH parts, and found this exploded view, and part numbers. Schematic, Manuals, Specifications and Diagrams for Disc assembly - 10-80,10-203,10-244,10-246,10-202,10-204,10-245, 10-247 | New Holland AG | MyCNHi US Store It says limited, but you have an oem part number to cross, through NAPA, or Motion Industries.
It is a P-AO-20 plow, which I found crosses to the MF 64/ MH64 2-disc plows. I will follow the link and see what it says —- THANK YOU!
   / Dearborn 2 disc plow parts #19
   / Dearborn 2 disc plow parts #20
What is the model number on that plow..?? If the tag is still on it, search parts at New Holland, using the model number. Search feature is at the top of this page, search by selecting model at right, then type in model number at left. It's hard to see it in the gray block at the top. Get Genuine OEM Parts and Replacement Parts | New Holland AG | MyCNHi US Store
I've never purchased anything through this place,but it always seem to pop up when doing a search for hard to find parts. Might be worth a call. https://spare.avspart.com/spare/new.holland/9n743/
Dragged it out of the hillside today - the discs run with two fingers!
the tail wheel is locked solid, which is not surprising since it was buried...
I will be getting out the PB Blaster and the 4-oz ball peen and do the spray-tap-tap-tap-spray-tap-tap-tap routine and see what happens...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
19009 (A48082)
19009 (A48082)
CATERPILLAR 259D3 SKID STEER (A51242)
CATERPILLAR 259D3...
5 Shank Inline Ripper (A50514)
5 Shank Inline...
71053 (A49346)
71053 (A49346)
