John Deere 425 Zero turn Hydraulic pipe leak
   / John Deere 425 Zero turn Hydraulic pipe leak
Anyone here ever worked on or replaced the "O" rings on a TUFF TORQ BY KANZAKI MODEL: DUP 10E S/N: 10E006141, if so would you please shed some light on your experience with this unit. :eek:
Well gentlemen, I think my leakage problem have been solved.
I was topping my reservoir off with the wrong weight oil, I was using AW-10 Hydraulic fluid.
The more 10 weight Hydraulic fluid I added to my reservoir the more the leak increased.
Once I started using the correct weight oil 20-50W motor oil the leak gradually subsided.
   / John Deere 425 Zero turn Hydraulic pipe leak #12
Isn't it great when things fix themselves !
It will be back.
Richard
   / John Deere 425 Zero turn Hydraulic pipe leak #13
It will be back.
Richard
I suppose things fixed itself when the owner/operator wised up and put the correct oil in the reservoir.
Almost a year now, since I put the correct oil in the reservoir, no leaks not even a wet spot.
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2022 VERMEER RTX250 WALK BEHIND TRENCHER (A53843)
2022 VERMEER...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2016 CATERPILLAR 325FL EXCAVATOR (A51246)
2016 CATERPILLAR...
