Good riding mower/tractor used for $500-1500?
   / Good riding mower/tractor used for $500-1500? #1
ShowroomShine
Gold Member
Raleigh NC
2019 Case IH 55A
Need a spare mower to keep at a second property so I dont have to trailer my BX back and forth every weekend. Even though this is a cheaper secondary mower, I'd still not rather buy a huge pile of crap machine. I was thinking an older Deere, Gravely etc?
What would you suggest for a riding mower (hydrostatic preferred) that can handle some grass mowing and maybe towing a cart around the yard for $500-1500?
   / Good riding mower/tractor used for $500-1500? #2
I have long since lost track of who makes what in the world of residential mowers. I suspect in your price range most any of the newer (used) residential models would be suitable for a second mower, ie John Deere, Husqvarna, CubCadet, etc. There are a LOT of these types of machines for sale used.
Getting an older and higher quality machine may serve well also, but need a little initial work if you're mechanically inclined.
Easy to spend someone else's money, but I gave up on residential machines years ago, and bite the bullet on commercial equipment.
Oh yeah me too, I only use commercial level stuff for my main yard and property….just can’t justify that for a second home. I thought about a good commercial walk behind mower but then it can’t tow a cart around so I figured a riding mower would probably still be best.
   / Good riding mower/tractor used for $500-1500? #4
Understood. A budget mower certainly doesn't compare to your BX machine! I use commercial equipment for my lawn, but mostly for my small lawn mowing retirement gig - 400-500 hours per year.
There should be a large selection of residential mowers available, have fun shopping.
   / Good riding mower/tractor used for $500-1500? #5
I don’t think you will be able to find a top tier used mower in hay price range; more like a big box store type of machine made by MTD. The best I could find in the under $1500 range is a Scotts brand mower or a lower end Deere mower.
   / Good riding mower/tractor used for $500-1500? #6
Good used mowers are rare as hens teeth. As a general rule nobody sells a ‘good’ used mower, they keep using it.
   / Good riding mower/tractor used for $500-1500? #7
I happened to find mine used from a guy who moved from a house with a large lot to a city house with a small yard.
   / Good riding mower/tractor used for $500-1500? #8
“If” you can find an older Craftsman GT5000/6000 type mower or it’s Husqvarna/Poulan/Dixon equivalent you can have a decent 2nd mower. Some parts are getting harder to find, but the wear stuff like belts/blades/spindles/electrics/etc. are still easily available. The 6 speed models are likely the most rugged.
2011 Hyundai Sonata (A51694)
2011 Hyundai...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
2016 CATERPILLAR 950M WHEEL LOADER (A51246)
2016 CATERPILLAR...
RING 3 STARTS HERE @ 9:30 AM (A51248)
RING 3 STARTS HERE...
PALLET OF JACKS AND STANDS (A53843)
PALLET OF JACKS...
