What happens??
   / What happens?? #1
LD48750
SE, MI
Ford 1510 Mahindra 1526
What happens when you put a 5/8" belt on/in a 1/2" pulley?
Electric PTO clutch running a Mid Mount Mower.
   / What happens?? #2
It may cause the entire tractor explodes into 10,000 pieces killing everyone within 100 feet. Other than that, it may wear out a little quicker and not be able to transmit as much torque because of the reduced contact area between belt and pulley.
   / What happens?? #3
1/16th hangs over each side. Will it rub anything? Is it the same type of belt? Same lenght? Just 1/8" too wide?
   / What happens??
Nothing that I can see. Same old belt, new clutch & pulley.
If that happens, I guess I'll have nothing to worry about.
   / What happens?? #5
You should be fine.
   / What happens?? #6
Trying to logistically think thru the question. Two things come to mind.
1. It may try to come off.
2. It may slip because of less friction.
   / What happens?? #7
I did that once and the belt looked like
confetti all shredded to crap. The belt
should always be just slightly inside the
outside edges of the pulley unless you
like buying and replacing belts
willy
   / What happens??
willy
Thats not what I wanted to hear.
Now when the new clutch gets here I'm going to have to see if I can exchange it.
Thanks for the info before I make the new part un-returnable.
   / What happens?? #9
Not sure how logistics figures into this equation.
Use the belt and let us know how it works. I think it will be fine.
   / What happens?? #10
Ummmmm,,,,, logistics as in the compatibility of two physical objects. The same logistical thought used to determine that a larger belt is needed in a specific application. Or a smaller belt needed in a different application.
If there were no logistical thought used all belts would be the same size.
Maybe we have differing definitions of logistics? :)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
HITACHI EX550LC EXCAVATOR (A58214)
HITACHI EX550LC...
Peterbilt 377 Semi-Truck (A56438)
Peterbilt 377...
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
2022 Horizon (A55973)
JLG 20MVL MANLIFT (A58214)
JLG 20MVL MANLIFT...
