I'll take a look. There is a 5/16 listed that has an ID of 0.272 which might be good enough. I would have to buy a flaring tool as I only have 45 degree tools.I would probably use Stainless lines and look for something with a 3,000 psi working. I would encourage you to go with 3/8" tubing as it will be close to 1/4" hoses in size. Tubing is measured by the OD and hose is measured by the ID. 1/4" tubing is extremely small and will be very very slow, the valve will basically be on or off with no feathering ability. A Ridgid 375 is a commonly used hand flaring tool however for 1/4" or 3/8" tubing I would suspect most flaring tools would work. For fittings Parker TX-S sleeves and BTX-S nuts would be the most economical choice.
Zoro has some reasonable tubing prices.
Strong & Resilient Stainless Steel Tubing | Zoro.com
Fittings for 3/8"
Triple-Lok 6 BTX-S $1.11 Nut | Zoro.com
Order Triple-Lok Nut, 6 BTX-S at Zoro.com. Spend less, save more with competitive pricing on Flared Tube Fittings at Zoro.com.www.zoro.com
Triple-Lok 6 TX-S $0.83 Sleeve | Zoro.com
Order Triple-Lok Sleeve, 6 TX-S at Zoro.com. Great prices & free shipping on orders over $50 when you sign in or sign up for an account.www.zoro.com
This is what is used on industrial equipment all the time and is a proven and durable approach.
It's for a top and tilt, with rather small cylinders. I've heard of people needing to put in flow restrictors to prevent slamming.
