Material for hydraulic hard lines, Copper-Nickel or only steel?
   / Material for hydraulic hard lines, Copper-Nickel or only steel?
I would probably use Stainless lines and look for something with a 3,000 psi working. I would encourage you to go with 3/8" tubing as it will be close to 1/4" hoses in size. Tubing is measured by the OD and hose is measured by the ID. 1/4" tubing is extremely small and will be very very slow, the valve will basically be on or off with no feathering ability. A Ridgid 375 is a commonly used hand flaring tool however for 1/4" or 3/8" tubing I would suspect most flaring tools would work. For fittings Parker TX-S sleeves and BTX-S nuts would be the most economical choice.
Zoro has some reasonable tubing prices.
Strong & Resilient Stainless Steel Tubing | Zoro.com
Fittings for 3/8"
This is what is used on industrial equipment all the time and is a proven and durable approach.
I'll take a look. There is a 5/16 listed that has an ID of 0.272 which might be good enough. I would have to buy a flaring tool as I only have 45 degree tools.
It's for a top and tilt, with rather small cylinders. I've heard of people needing to put in flow restrictors to prevent slamming.
What are you using to bend the lines? Whenever I have had to bend small diameter stainless, brass, or copper tubing I used a tubing bender and had no trouble with kinking or distorting the round shape of the tube.
Eric
Have a couple styles of hand held tubing benders that more or less work OK.
More I look into this, may just go with flexible hoses. By the time I get the materials and a decent flaring tool, I'll be even older and poorer than now.
   / Material for hydraulic hard lines, Copper-Nickel or only steel? #13
Probably a good choice, hardlines for a one-time project rarely makes sense.
One of my concerns is the "bend radius" as the hoses will be under a foot long. Dawns on me I should get one made up locally and see how it looks, then go from there. I'll only be out about $30 if it does not work out.
   / Material for hydraulic hard lines, Copper-Nickel or only steel? #15
A 3/8" hose can bend pretty tightly.
   / Material for hydraulic hard lines, Copper-Nickel or only steel? #16
For bending tubing, especially when the wall thickness is pretty thin, a good fitting tubing bender will is almost a must. I think you're correct in looking into flexible hoses.
Eric
   / Material for hydraulic hard lines, Copper-Nickel or only steel? #17
Proper rated tubing and compression fittings!
Compression fittings for a 2100 PSI system? I was having a hard time convincing myself to use them on the tank return line, which I have have to resort to.
I tried removing the JIC male adapter threaded into the tank return on the hydrostatic, to figure out a replacement, so I could insert a T in that space, but managed about three turns before it got very hard to turn. Discretion VS VS Valor convinced me to thread it back in and go a different route. Guessing it is one of those tapered pipe threads and is well and truly distorted.
   / Material for hydraulic hard lines, Copper-Nickel or only steel? #19
I'm assuming he used that as a general term, and what he really means is "swagelock" style fittings, they are made for high pressure use.
   / Material for hydraulic hard lines, Copper-Nickel or only steel? #20
Joea99, if you were closer I could bend and flare steel lines while you wait, I have .250” to 1.500”.
Some types of stainless tubing doesn’t like to bend or flare, you would need to specify annealed tubing.
2015 Kia Cadenza Sedan (A53424)
2015 Kia Cadenza...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
2017 Chevrolet Silverado Schwarze SuperVac Updraft Sweeper Truck (A55852)
2017 Chevrolet...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
