DIY Starlink Temporary non-penetrating roof option mount (Cheap and Easy)
   / DIY Starlink Temporary non-penetrating roof option mount (Cheap and Easy) #1
miscjames
Kubota L3901
Here is a DIY Starlink Temporary non-penetrating roof option mount that is cheap (almost free) and easy to move around.
While trying to find a mounting spot on my roof that give me the best signal, this is what i came up with.
I hope this helps someone. #Startlink #StarlinkMusk #SpaceX
   / DIY Starlink Temporary non-penetrating roof option mount (Cheap and Easy) #2
Do you need to use a Radial or will Bias Ply work also? ;)
   / DIY Starlink Temporary non-penetrating roof option mount (Cheap and Easy) #3
Good idea. If you really wanted to go all out, a rear R1 tractor tire would work as well. Problem would be getting it up there, they are super heavy.
Gonna copy it but with a used R1 instead.
   / DIY Starlink Temporary non-penetrating roof option mount (Cheap and Easy) #4
I kinda like that idea. I may do that, even if i put it on the ground, either one or two tires. I'll just have to make sure i cut holes to let the rain water out so's not to have a nice breeding area for mosquitoes.
   / DIY Starlink Temporary non-penetrating roof option mount (Cheap and Easy) #7
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
23018 (A53424)
23018 (A53424)
6 FOOT UTILITY TRAILER WITH MOTOR (A53843)
6 FOOT UTILITY...
2008 KOMATSU PC200LC-8 EXCAVATOR (A52706)
2008 KOMATSU...
