JD 1050 major spill of motor oil
   / JD 1050 major spill of motor oil #1
farmer marx
Member
brattleboro VT
deere la105
To make it quick: I saw burned motor oil spraying out of an overflow rubber tube coming from the area of the fuel injectors.
I turned it off and wanted to check the oil level. As soon as I took off the cap, the oil came out like tilting a gallon jug on the side at once,
a jet 3-4 inch long and a lot of it.
It clearly came from up higher because it stopped when it reached the level of the tank opening.
Obviously there is a big problem somewhere, but what is the most likely cause?
Is there anybody that has a suggestion?
Thank you in advance.
Farmer Marx
   / JD 1050 major spill of motor oil #2
If you don't have a diesel smell my guess is a leaky seal on your hydraulic pump. Due to the quantity of hydraulic fluid in a tractor you may not notice if it's a couple quarts low but you'll sure notice if your oil pan is a couple high.
   / JD 1050 major spill of motor oil #3
Farmer Marx
You'll have to determine if it is diesel or hydraulic fluid getting into the engine oil. The 3 main culprits are usually fuel lift pump, injector pump or hydraulic pump.
Thank you. The hydraulic fluid tank is full so I would exclude that. I need to find out about diesel and injectors. Thanks again.
Thank you, most likely I will need an expert to look into it. I dont' have enough experience for this level of complexity but I will do what I can to try to eliminate some of the possible causes. Your insight was very helpful.
   / JD 1050 major spill of motor oil #6
I would be sure to check the fuel lift pump (if equipped) first. It is the easiest and cheapest to fix of the three.
I will check the service manual. I just got a new copy after the guy who came to my house to service my tractor 6 months ago stole the original.
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
5004 (A55851)
5004 (A55851)
2015 DRAGON 130BBL VAC TRAILER (A55745)
2015 DRAGON 130BBL...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
