Kubota BT750 Swing Sensor Part# 78621-73342
   / Kubota BT750 Swing Sensor Part# 78621-73342 #1
intruderfta
Ontario, Canada
B20 FEL, BH, B3030HSDCC FEL, ,
I have a Kubota Backhoe BT750 which has an electrical (12v) solenoid activated hydraulic boom swing to the right and the left.
The switch that controlls this is a momentary switch that Kubota calls a swing sensor.
There is no stock showing anywhere and according to Kubota is no longer available in North America or anywhere else.
Would anyone have one? Either new or used that they would be willing to sell?
   / Kubota BT750 Swing Sensor Part# 78621-73342 #2
I just Googled that part number and several US vendors popped up.......Don
Maybe I missed the boat here since I didn't actually check any of the links to see if they had the part on hand.
   / Kubota BT750 Swing Sensor Part# 78621-73342 #3
Sorry I can not help with the part number but here is a link that might interest you.
Or you could possibly convert to completely manual operation and take out the auto return. Not exactly sure how that goes though.
Hope this helps!!
Hi Don
Could i ask you to list the vendors as I have tried that with no luck. I can then call each of them to see if they have stock.
sincerely
Ken
   / Kubota BT750 Swing Sensor Part# 78621-73342 #5
Ken, here's two but there was a couple more. Like I said though, I didn't open the sites to see if they had the part in stock.
Good luck............Don
2021 Toyota Corolla LE Sedan (A53424)
2021 Toyota...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
40' CONTAINER (A51244)
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2002 VOLVO L150F WHEEL LOADER (A51406)
2002 VOLVO L150F...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A55302)
2023 Kubota...
