While bush hogging I got bogged down and tractor died now it won't start lights work but will not cran
   / While bush hogging I got bogged down and tractor died now it won't start lights work but will not cran #1
Aprillvsromeo1
Ford 1530
While bush hogging I got bogged down and it died now it won't start I disengaged the pto and put in neutral still won't crank
   / While bush hogging I got bogged down and tractor died now it won't start lights work but will not cran #2
Are you saying that it won't crank over with the starter or that the engine won't start and run? IF it's not turning over than I would look for maybe a safety switch that the wires got pulled off by brush.
   / While bush hogging I got bogged down and tractor died now it won't start lights work but will not cran #3
Are you saying that it won't crank over with the starter or that the engine won't start and run? IF it's not turning over than I would look for maybe a safety switch that the wires got pulled off by I would also check fuses.
I would also check fuses. I had similar happen and it was a faulty plug in the wiring harness that keep blowing the fuse.
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A55218)
2019 BOBCAT T630...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55218)
2012 RAM 5500...
UNUSED DIGGIT HEAVY DUTY 20'X20' ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
2007 Fontaine DFT-5-8048WSAWK 48ft 35 Ton Drop Deck Equipment Trailer (A52377)
2007 Fontaine...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
