MF 135 3 point link wont lift with weight on
   / MF 135 3 point link wont lift with weight on #1
Massey135GK
Massey Ferguson 135
Hi all,
I have a massey 135 which I put a new hydraulic pump on about 4 months ago, she will work fine on the log splitter but will not lift weight on the 3 point linkage. It will lift my link box empty but as soon as I add weight it drops to the ground. So far I have checked the following and all seems to be okay:
Side cover removed & checked fingers are in correct place as well as cricket bale still in situ.
No water in oil - oil is only four months old and looks as new as the day it went in.
Removed hydraulic cover cap to check stand pipe washers - all well and oil is horsing out of the stand pipe with plenty of pressure.
I believe it means I am going to need to remove the top cover as this is the only place i think there may be an issue.
Any assistance or hints would be greatly appreciated
Thanks
Ga
   / MF 135 3 point link wont lift with weight on #2
Any slack in the toplink?
There is up and down movement as well as side to side but no in and out movement on the top link, it is fixed solid
   / MF 135 3 point link wont lift with weight on #4
shot in the dark from someone with ZERO knowledge of that tractor....possible air bound somewhere affecting ONLY that movement???
That's a good possibility but how I check it or push the air through I have no idea
   / MF 135 3 point link wont lift with weight on #6
wish I knew how, sorry
   / MF 135 3 point link wont lift with weight on #7
Those old MFs are not airtight so I wouldn't worry about it.
   / MF 135 3 point link wont lift with weight on #8
You are using the position control?
  • Good Post
Reactions: JWR
   / MF 135 3 point link wont lift with weight on #9
Bought a fully restored Ford tractor about 40 years ago. Everything worked fine except it could not lift my brushcutter. Returned it in exchange for a MF which was very good. Regret not holding on to that (Model N, I think about a 1950 build).
Yeah I am, I've since tried disconnecting the top link and just using the arms to lift and that's no problem and stay up so must have an issue in either the draft controll or top lid somewhere 🤔
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A55218)
1992 Talbert 70...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2016 John Deere Gator 825i 4x4 Utility Cart (A53421)
2016 John Deere...
2017 TAKEUCHI TB240 EXCAVATOR (A52705)
2017 TAKEUCHI...
