E-15 fuel in your area?
   / E-15 fuel in your area? #1
tomplum
Elite Member
PNW
XJ2025H
I haven't seen it around me. It seems to be a resoundingly bad idea. Our Kohler engine distributor reiterated that it was not suitable in OPE.
E15​
The U.S. Environmental Protection Agency (EPA) defines E15 as gasoline blended with 10.5% to 15% ethanol. In 2011, EPA approved E15 for use in light-duty conventional vehicles of model year 2001 and newer, through a Clean Air Act waiver request, based on significant testing and research funded by the U.S. Department of Energy. Stations are not required to sell E15, but some have started offering E15 due to state and federal incentives for upgrading equipment and better profit margins when compared with regular gasoline. E15 is available in 30 states at just over 2,400 stations. E10 remains the limit for passenger vehicles older than model year 2001 and for other non-road and small engines and vehicles that use gasoline, such as lawn mowers, motorcycles, and boats.
Vehicles approved for E15 use:
  • Flexible fuel vehicles
  • Conventional vehicles of model year 2001 and newer.
Vehicles prohibited from using E15:
  • All motorcycles
  • All vehicles with heavy-duty engines, such as school buses and delivery trucks
  • All off-road vehicles, such as boats and snowmobiles
  • All engines in off-road equipment, such as chain saws and gasoline lawn mowers
  • All conventional vehicles older than model year 2001.
There are additional regulations for stations selling blends above E10. For more information, visit the Codes, Standards, and Safety page.
   / E-15 fuel in your area? #3
I attempted to find more info on E10 blended fuel yrs ago trying to figure out why my mpgs dropped 10-20% when I started using E10 still haven't found a valid compelling argument. I can't understand why blending fuel will reduce oil consumption for gasoline when you just need to burn more of it to travel the same distance. I won't even get started on all the small engine problems, that in a smaller scale the average middle class person has to deal with out of pocket.
   / E-15 fuel in your area? #4
Ethanol has about 2/3 the BTUs of gasoline. Mileage with E10 would drop by 2/3 of 10% or 3.3%, assuming the air/fuel mixture stays the same. On a vehicle with EFI and an O2 sensor, the ECU will adjust fuel to keep the O2 level in the correct range. That may mean more fuel consumption than that 3.3% from the fuel chemistry. 20% mileage drop seems excessive however.
We're not seeing E15 here in my part of CA yet, fortunately.
The ethanol industry has been pushing for E15 for years. No one else wants it. It actually produces more CO2 than the equivalent amount of gasoline, mostly due to the way it's farmed:
   / E-15 fuel in your area? #5
Thanks that was a great response. My truck at the time was a old Toyota with earlier efi. Does burning E10 with a 3-5% reduction in mpgs reduce or increase CO2 output what about the resources, energy, and carbon output it takes to manufacture corn based ethanol?
   / E-15 fuel in your area? #6
Ok re read the article thanks again. Lol I tried to find my answers years ago before the internet was prevalent, worse fuel mileage, and formerly reliable two strokes were getting rebuilt/ rebored/ replated constantly with pretty bad scoring on the exhaust port side.
   / E-15 fuel in your area? #7
That's kind of misleading.
E100 (pure ethanol) has about 76,000 BTU per gallon.
Pure gasoline has about 114,000 BTU per gallon.
E10 (10% ethanol 90% gasoline) has about 111,800 BTU per gallon.
111,800 is 98.07% of 114,000.
Less than 2% difference in BTU.
   / E-15 fuel in your area? #8
Put another way, if your car gets 30mpg on pure gasoline, it will get 29.4mpg on E10.
   / E-15 fuel in your area? #9
I've been running E10 87 octane since the mid 80's in everything I own until a recent chainsaw purchase requires 89. Two stroke, four stroke, doesn't matter. I've never had any problems that can be traced to ethanol. Why? Because I either run the machines often enough to turn the fuel over regularly, or, I follow the manufacturer's recommendations for long term storage.
I'd guess 99% of problems that people think are caused by ethanol are actually caused by poor maintenance practices.
   / E-15 fuel in your area? #10
Just last week I tested the gas I got at my local station, no corn products thankfully, only gas. Here's hoping it never shows up.
Stupid question, if all the stations in a particular area only sell regular E85, does that mean you've got to run hi test in everything that's not E85 approved?, that'll go over like a lead brick, more $$$$............Mike
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2005 Toro Workman 175 Sprayer Cart (A50322)
2005 Toro Workman...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
Kinze 3500 8 Row Vac Planter (A52349)
Kinze 3500 8 Row...
Skid Mounted Controls (A50121)
Skid Mounted...
