E-15 fuel in your area?
   / E-15 fuel in your area? #11
That's kind of misleading.
E100 (pure ethanol) has about 76,000 BTU per gallon.
Pure gasoline has about 114,000 BTU per gallon.
E10 (10% ethanol 90% gasoline) has about 111,800 BTU per gallon.
111,800 is 98.07% of 114,000.
Less than 2% difference in BTU.
I've been running E10 87 octane since the mid 80's in everything I own until a recent chainsaw purchase requires 89. Two stroke, four stroke, doesn't matter. I've never had any problems that can be traced to ethanol. Why? Because I either run the machines often enough to turn the fuel over regularly, or, I follow the manufacturer's recommendations for long term storage.
I'd guess 99% of problems that people think are caused by ethanol are actually caused by poor maintenance practices.
Put another way, if your car gets 30mpg on pure gasoline, it will get 29.4mpg on E10.
Maybe you should experiment on a few tanks of gas? mine don't that I know for a fact even with todays cars, however the cost benefit of buying ethanol free vs pure gas is not there unless it's for small engines only to keep them somewhat reliable, and help prevent costly repairs. Yes, I think I maintain my stuff better than most and most is old and used up.
   / E-15 fuel in your area? #12
Just last week I tested the gas I got at my local station, no corn products thankfully, only gas. Here's hoping it never shows up.
Stupid question, if all the stations in a particular area only sell regular E85, does that mean you've got to run hi test in everything that's not E85 approved?, that'll go over like a lead brick, more $$$$............Mike
They can't only sell E85 at this time I believe.
   / E-15 fuel in your area? #13
Sounds like we should all switch to diesel…
   / E-15 fuel in your area? #14
This is false because a lot of plastics and rubber components were never designed to be compatible, there was a transition period and items (mostly small engines, can’t think of a automobile engine) had to be upgraded to compatible components. Not much room for debate on that one
   / E-15 fuel in your area? #15
It said non-ethanol? If it didn’t, there is ethanol in there.
   / E-15 fuel in your area? #16
The NMMA has been fighting E15 mandates forever or it seems like. They don't have much financial benefit by doing this unless they just want to protect consumers manufacturers.
   / E-15 fuel in your area? #17
I’m not sure what price fuel would have to reach to make it cost effective to use ethanol. I do know it uses a lot of land, a lot of fertilizer, a lot of machines, and a lot of FUEL to produce so with the cost of all those inputs rising…I’m not a huge fan.
   / E-15 fuel in your area? #19
I've used these I recently tested them on a non running JD 212 I bought for $50. test showed it was bad gas with water and I assume phase separation. Drained fuel tank, cleaned carb and fuel pump it started right up and runs great. Point is the testing swabs worked like they should
   / E-15 fuel in your area? #20
I've never seen a station that only sells E85.
2018 JLG 4045R 40ft Electric Scissor Lift (A50322)
2018 JLG 4045R...
2016 JLG 2646ES 26ft Electric Scissor Lift (A50322)
2016 JLG 2646ES...
2015 Kia Forte Sedan (A50324)
2015 Kia Forte...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
