3-Point Hitch Challenged to remove pin - Kubota L3540 Lift Arm
   / Challenged to remove pin - Kubota L3540 Lift Arm #21
Reviving a few year old thread. Geez. I've been trying to get the bolt out and even used a bearing puller. Got a good grip. Bent the friggin bearing puller. I've put Kroll, PB blaster on it. I'm thinking of putting some heat on the bolt only to maybe break the bond there. Dont want to heat the arm.
   / Challenged to remove pin - Kubota L3540 Lift Arm #22
I have had good luck using a puller plus an air hammer.
The rapid pounding of the air hammer will tend to jar stuff free where just pressure wont.
Dave M7040
2016 Kenworth T880 T/A Vactor 2112P-16 Combination Sewer Jetter Vacuum Truck (A50323)
2016 Kenworth T880...
2016 Chevrolet Cruze Sedan (A50324)
2016 Chevrolet...
2022 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2014 FREIGHTLINER...
2014 AUTOCAR EXPEDITOR GARBAGE TRUCK (A51219)
2014 AUTOCAR...
