On my 2310, I find I have to rotate my slip collar end onto the mid-PTO shaft several times until it slides on... sure feels like it's keyed to me, on both ends. (MMM end has a white mark on the deck and the shaft to save time.)
			I'll double check today but I've always been able to slide it on in multiple orientations as long as l have the shaft straight. I just wiggle either the output shaft or the collar end.On my 2310, I find I have to rotate my slip collar end onto the mid-PTO shaft several times until it slides on... sure feels like it's keyed to me, on both ends. (MMM end has a white mark on the deck and the shaft to save time.)
Yes, the two halves of the pto shaft are keyed. One of the splines is slightly wider than the rest. It is not easy to tell the difference on the MMM side.Now to figure out how to put a keyed PTO shaft, onto a non-keyed shaft. This was how I got it new on my 2326 MMM. Pic for ref after some persuasion to get them together. Dealer couldnt grasp that one side was keyed, and the other side wasnt... making it near impossible without damage to get them together. I think I will have to spring for a new half after I figure out if they installed the right shafts together. Do any of you have the same MMM? Is one side of your shaft not keyed (attaches to MMM) and the other half keyed (attaches to tractor PTO)?
mine has (from factory) a white paint mark on shaft end denoting the larger spline. the female end has no markings but the larger spline is easy to see. course when mating the 2 you always get at least one hand all covered in grease.PS--the white marks on the PTO-end of my MMM shaft are "Wite-Out" stripes that I put on; there was nothing there from the factory.
