How Much Metal do I Need to Leave on SSQA Mount?
   / How Much Metal do I Need to Leave on SSQA Mount? #1
Suburban Plowboy
FL
Kubota L3710
Here is where I am at in converting my Kubota 60" LA681 bucket to SSQA. Removing the ears was not a lot of fun.
I have a solid 3/8" mount plate waiting to be attached. Obviously, I don't need all this metal, but I couldn't get exactly what I want, so I am going to cut this plate down.
How much metal do I need to leave behind? Can I cut the ends off the mount and use those without anything joining them? That would make painting the bucket a lot easier when I'm done, and I might be able to use the scrap from the mount as the basis for mounts for something else.
I saw somebody on the web saying he had one plate on each end of the bucket, and they were about 7" wide. I can't recall if that was here or elsewhere.
I would think that if the amount of weld was equal to or greater to the amount on the original bucket ears, I should have a strong bucket.
   / How Much Metal do I Need to Leave on SSQA Mount? #2
I would assume that the angle turned the stupid way is necessary, at least in kubota's opinion and try to retain that. A picture of your ssqa plate leaned up against the bucket would help us with suggestions. I can see that you'll need to support the lower "area" on the plate. They are about 18"
and your flat surface looks to be about 10".
Put a picture up.
   / How Much Metal do I Need to Leave on SSQA Mount? #3
Just did one exactly like that for a customer actually.
It's hard to see much in the photos, but here they are.
Here's a capture of a Youtube video in which someone put a mount on pretty much the same bucket. He cut the entire angle iron out, which seems like a bad idea to me. His mount was just two plates connected by a thin strip of metal.
I don't see what that thin strip does that is of any use. I can leave most of the angle iron in place and weld it to the SSQA plates.
   / How Much Metal do I Need to Leave on SSQA Mount? #6
Will that angle fit in between the ssqa and its pin and spring assembly providing you cut the plate?
It will fit if I make it fit. I have already cut around 4" of the angle iron out because it made getting the ears off hard and I knew I was going to have to cut some out anyway. I plan to cut a little more out before welding the mount on. Looks like I will lose around 4-6".
   / How Much Metal do I Need to Leave on SSQA Mount? #8
It basically just serves to keep the plates aligned and spaced while being installed. If it's welded continuously it would provide just a bit of reinforcement.
   / How Much Metal do I Need to Leave on SSQA Mount? #10
You need to use "enough" material so the attachment doesn't fall off and cause damage to equipment/property or bodily injury.
"enough" is determined by the grade of materials used, thickness, geometry and applied loads. Now add a factor of safety.
2022 Bobcat T770 Compact Track Loader Skid Steer (A49461)
2022 Bobcat T770...
2017 KOMATSU PC228USLC-10 EXCAVATOR (A51242)
2017 KOMATSU...
2018 FORD F-150 XL (A50854)
2018 FORD F-150 XL...
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
Ford 641 Workmaster (A50514)
Ford 641...
2013 Jeep Patriot (A50324)
2013 Jeep Patriot...
