tc 24 d hydro oil braking rubber coupling and no reverse / forward
   / tc 24 d hydro oil braking rubber coupling and no reverse / forward #1
blazing bee
new holland TC 24 D
I have new holland tc 24 d that has no reverse or forward and oil is pressurized so much it comes out of oil filter oil seal or breaks the rubber coupling to oil cooler .This all started after i replace the housing for linkage after i hit a stump and crack the housing . I was thinking it maybe a clogged oil cooler inside the fins . Anybody have any ideas' what causing it
   / tc 24 d hydro oil braking rubber coupling and no reverse / forward #2
Not sure which housing and linkage you are talking about? Pictures would certainly help along with a better explanation of what was taken out by the stump. Oil should not be pressurized at the filter. Sounds like something was hooked up incorrectly...??
I cracked the middle housing that supports mid mount mower . This is the the 3 rd time this has happen , i never had a problem like i am expercinging now. After starting tractor the oil pushes through oil filter rubber gasket , so i tighten that further and then it blew through rubber coupling that joins oil cooler , so i retighten that and then it explodes underneath where metal hydro tubing joins together with rubber coupling . My symptoms are no reverse or forward , bucket and pto works fine . I think its a blown valve body one of the oil seals are bad but not sure on that . Looking for help . What i have done is to drill a hole in bottom of oil filter and ran a hose to back of tractor where you fill up hydro oil so i can a least run engine . It keeps it from exploding oil from gasket or rubber couplings
   / tc 24 d hydro oil braking rubber coupling and no reverse / forward #4
Yes pictures would certaintly help.
Are you refering to item #1 in the attached that cracked?
  • nh-148592-343091-2352428.pdf
2021 TAKEUCHI TB235-2 EXCAVATOR (A52706)
2021 TAKEUCHI...
2015 Toyota Prius (A53424)
2015 Toyota Prius...
2012 Cadillac CTS Sedan (A53424)
2012 Cadillac CTS...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
Killbros Fold-up Rolling Basket (A50775)
Killbros Fold-up...
