Good morning!!!!
   / Good morning!!!! #151,981
today I will rethink my issues with that one failed bolt. Probably will drill out the hole further so nut can spin. I simply ran out of energy and patience.
Drilling a new bolt hole with adequate clearance is a good idea...
As far as the hole drilled too close, you can always plug it using a cut down bolt or a dowel and epoxy it in place, than paint...assuming it worries you
   / Good morning!!!! #151,982
Hope the Mrs. recovering quickly Buppies.
   / Good morning!!!! #151,983
Hope your feeling heck of lot better Randy.
   / Good morning!!!! #151,984
Good Morning
daugen- that exhaust is puzzling, probably customized just for show. I can't decide on year because I can't figure out the triple chromed side vents. The front grille trim should give hints, but it seems altered also. it could be a Special Deluxe, but I was putting my bet on Belvedere.
eager for my zero turn to be ready, almost time to mow again. also waiting (patiently ?) for my new rims and tires for the truck. I think the re-homed RooPaul2 will recover nicely, and hopefully fit-in with the new birds. I will be cleaning the second incubator today so that I can use it for the homestretch as it is more reliable. the broody hens are doing fine, but I am only leaving them the eggs that I have not already marked. yardwork will probably wait for better weather on the weekend. I have a plan to re-use an old water crate / 1000 L tote thingy's ... the tote is removed as it was broken - so it is just the base and frame. I am going to attach 1/4 inch wire mesh to the sides with zapstraps or wire, then flip the entire unit upside down, and use it as a "chicken tractor" for the young birds. that should keep them safe, and sheltered until they are big enough to join the others.
My wife should be home from assisting her father this weekend (8 hrs away). it's been long enough
we are getting mixed weather all week about 20 C, and rain, clouds. the sun will shine on the weekend, perhaps in time for Friday's ice-cream cruise with the classic / muscle cars :)
Thomas - greetings
prayers continue as per previous days
   / Good morning!!!! #151,985
Scaredy, old car had some kind of flames on the side too
It did not look like a desirable ride, rode hard and put away wet.
But maybe that's exactly the way he wants it.
   / Good morning!!!! #151,986
50F partly cloudy maybe sprinkle later today mid 70's for high.
First day of summer...fingers cross for cooler temps and refilling streams ponds lakes mid west etc.
Last evening Mrs. and I got to watch one of many nature fine moments live from the deck,Boo came to visit laid down by the feeding area,2 siblings cubs plan was to get Boo to move away,1 cub went behind Boo walk about woods breaking limbs other cub slowly facing Boo move little closer,Boo took his paw slaps ground twice cub facing Boo back away quickly...plan2 both cubs face Boo slowly made there way towards Boo,Boo stood up tilt his head open his mouth show teeth gave quick heavy growl cubs made tracks with ears back disappear :oops: Boo laid back down took nap...wish I hadn't left camcorder in pickup.
Plans for today...Critter food run,afternoon doctor appointment.
Enjoy your day all.
   / Good morning!!!! #151,987
good idea. I'm going to do what I should have done, with a new drill bit so no excuses there.
My Appalachian engineering with construction adhesive always was Plan B.
Plan A was just going to miraculously appear....
I don't expect to ever take this apart so if I booger it up a little in the process, we will all survive.
Thomas, wonderful bear encounter. Be careful and always know where the door is...
   / Good morning!!!! #151,988
Morning all;
It's a nice 60F out this morning going into the mid 70's and should be dry.
My self I'm a bit stiff and sore this morning, had my electrician here yesterday to work on the kitchen remodel.
So I was electricians helper and will be again today and likely a couple more days. More
physical work then I've done for awhile. Even the artificial knee was tight and aching last night and this morning.
Crawl space work today and tomorrow, that will be fun, at least the crawl space is about 4 ft high.
Everyone take care and get well or stay so.
   / Good morning!!!! #151,989
Drew, Another way might to drill s 1/2 inch hole in the side of the stake pockets and put in a 1/2 inch shackle. Of course they make stake pocket adapters. I have seen twist drill bits which say in the fine print "not recommended for steel". What is the use of that? Good luck.
Chris
   / Good morning!!!! #151,990
Chris, thanks. I'm looking for the words cobalt or carbide.
never thought I'd get that Makita hot but I sure did. Seemed to run great after fifteen minutes in fridge.
There's only one way to do this the right way. Lots of ways to make it look good.
In insurance terms, it would have an inherent defect. Meaning you knew darn well it wasn't built right.
let's see what Truvalue has to offer me today
1999 Ford F-450 Mason Dump Truck (A53422)
1999 Ford F-450...
Year: 2015 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A56859)
Year: 2015 Make...
2016 Ford F-550 Enclosed Service Truck (A55852)
2016 Ford F-550...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2014 Ford Escape AWD SUV (A55853)
2014 Ford Escape...
2010 Ford F-750 Stellar 10621 10,000LB 5 Ton Crane Mechanics Truck (A51692)
2010 Ford F-750...
