Metrobill9
- Joined
 - Jun 23, 2022
- Messages
 - 4
- Tractor
 - Jinma 284
Hi have a jinma 284 with the engine y385. bucket and power steering not working check hydraulic fluid new to tractors please help
			Replaced pump still not workingI have a bigger Jinma the 354.
PS pump and hydraulics pump are separate.
Yours only has one pump??
Have you found your problem yet? If you have a pre 2006, 284 the hydraulic filter is located in the sump under the seat. Just remove the (3) bolts that connects the "suction out" fitting to the sump. The OEM filter is not engineered very good. I replaced my filter with a Massey Ferguson filter #1687042M91. There are multiple filters attached to this number so BE SURE to purchase the one that's 3 1/2 in. tall and the diameter about 2 1/4 in. You'll have to do some modifications on the filter but it works fine and is MUCH less expensive than the OEM. I posted the mod on the "Chinese Tractors" forum but didn't take any pictures (my bad). If you need any help with the mod just "Reply" to the post on "Chinese Tractors". Good luck!!!Hi have a jinma 284 with the engine y385. bucket and power steering not working check hydraulic fluid new to tractors please help
