Old BCS 725 working pto, but without power to the wheels.any help troubleshooting would be much appreciated.
   / Old BCS 725 working pto, but without power to the wheels.any help troubleshooting would be much appreciated. #1
Tjgob22
Ukiah1339
as the subject indicates,I have an old BCS 725 with a working pto but no drive to the wheels in any gear.Ive taken the gearbox apart and inspected the gear shifter arm and spring pins.It looks fine,without play in the action,as does everything else.Im baffled and could use some input.Thanks ahead of time for any advice and input.
   / Old BCS 725 working pto, but without power to the wheels.any help troubleshooting would be much appreciated. #2
Sound like a clutch is not grabbing, not sure how those new fangled two wheelers work, as I only have Gravelys. My guess is clutch. Not worn out, just not doing what it is supposed to be doing.
Someone will be along shortly that knows these. You could also call Joel at earth tools.
   / Old BCS 725 working pto, but without power to the wheels.any help troubleshooting would be much appreciated. #3
Check the clutch cable adjustment. Be sure to release the clutch after starting. If no success take off engine and inspect clutch and attachment to shafts
2000 Wabash National 53ft T/A Dry Van Trailer (A51692)
2000 Wabash...
2017 JOHN DEERE Z950M LOT NUMBER 86 (A53084)
2017 JOHN DEERE...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
City of Buckhannon - 2014 Ford Fusion SE (A52384)
City of Buckhannon...
