What paint to put numbers on a 27 gallon black plastic tote?
   / What paint to put numbers on a 27 gallon black plastic tote? #11
Thanks,
Krylon fusion for plastic linky must be new and is going for about $40/can, or 12 ounces. That's almost military pricing.
I went for the old style at Walmart ~ $7/can. linky
Wall Marks has it for plaxtid larn funiture. I'd never buy that high stuff. It ain't me. Probably a wood burning iron for me to do plastic.
   / What paint to put numbers on a 27 gallon black plastic tote? #12
We use very similar totes. Black Sharpie on the lids, White Sharpie on the totes. No need for tape, it will always eventually fail.
As noted above, have used Silver, too.
   / What paint to put numbers on a 27 gallon black plastic tote? #13
jf you insist on painted numbers you could try automotive paint (expensive) or acrylic paint from an art supply house (affordable). You will need to get a Gesso, like a primer, for the acrylic
   / What paint to put numbers on a 27 gallon black plastic tote? #15
I scuff it with a ScotchBright pad, and then use the Brother “Extra Strength Adhesive” Label Tape.
Some of these will end up on high shelves, maybe 12' up. I want BIG numbers to be easy to see. The largest my PDT 600 does is 1", definitely not big enough for me.
   / What paint to put numbers on a 27 gallon black plastic tote? #17
This thread reminds me of the warehouse from Indiana Jones and the Ark of the Covenant.
Everything stenciled, "TOP SECRET. Do Not Open."
   / What paint to put numbers on a 27 gallon black plastic tote? #18
The tubs are probably high density polyethylene - not much sticks to that as you have found out. There are some rattle cans that are for plastic, but check the label to see what they recommend. They might say something about priming or which materials it won't work on.
There is another trick in the industry for activating the surface better. You can do a surface treatment like corona or plasma, but those are not for the home shop... but flame treating can be done with a basic propane torch. The trick is you are not looking to heat up the surface of the plastic but just trying to wave the flame (which is essentially a plasma) over it. Get it close-ish, move pretty quick and don't stop. Then mark it within a few minutes and it should hold up a lot better. You will want to make multiple passes to cover larger areas, but again, move fast and don't pause - ever.
   / What paint to put numbers on a 27 gallon black plastic tote? #19
You could affix label cards to the totes, and mark them. I’d melt holes for pop rivets with a soldering iron, to lessen the odds of it splitting out and away from the holes.
1981 AZTEC SKINNY NECK 31 FOOT FLATBED (A53843)
1981 AZTEC SKINNY...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A55218)
2021 NEW HOLLAND...
Kubota SVL95-2 High Flow Cab Skid Steer (A55218)
Kubota SVL95-2...
HarbinGer V3 Plus S/A Towable Light Tower (A52377)
HarbinGer V3 Plus...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
2018 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2018 PRINOTH...
