need to flush hydraulic cavity on john deere 5055 E
   / need to flush hydraulic cavity on john deere 5055 E #1
porkinbean
john deere 5055e
My suction screen on my hydralic system is plugged with some debre and i need to flush the system. how can i do that and what is best to use to do that.
   / need to flush hydraulic cavity on john deere 5055 E #2
I don't know of any best way to do that. What I have done is simply change all the filters and oil several times and in between changes exercising the hydraulics in every way I can think of. There isn't a much better cleaner than hot oil, and the screen filter gives you access to the sump.
Once the debris makes it too the bottom of the sump (hydraulic cavity) I figure the tractor is safe.
good luck, and tell us how it goes.
rScotty
I just recently aquired the tractor from a family member. he said the tractor had been setting up about 10 months. I think it was a lot longer than that. when i got it it would not run. Had to replace the fuel pump. then the hydraulics were very jerky when operated. I drained the fluid and pulled the screen out and it was completly clogged with what looked like algie. cleaned it and replaced the fluid and filter. have about 5 hours run time on it and the hydraulics started jerking again. drained the fluid and pulled the screen again and it was completly clogged with some type of fiber like material???
   / need to flush hydraulic cavity on john deere 5055 E #4
Do you have any pictures to show us what this "fiber like material" looks like?
this is a picture of the filter screen. I have a picture of one large part of the fiber on my phone but it did not transfer. I will try to upload it.
This is the large piece that i found.1/16 thick very thin
Problem found. The debris is from the brake assembly. Had a mechanic look at it. Estimated repair $1000. Ouch!
   / need to flush hydraulic cavity on john deere 5055 E #8
That is unfortunate!! Thanks for letting us know about the issue!!
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Forks...
(2) CAM2 HI TEMP LITHIUM COMPLEX GREASE DRUMS (A54757)
(2) CAM2 HI TEMP...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
2019 ISUZU NPR 16FT BOX TRUCK (A56129)
2019 ISUZU NPR...
2008 Pierce Enforcer Ladder Fire Truck (A55852)
2008 Pierce...
2017 Ford F-550 Stellar EC5000 2.5 Ton Crane Service Truck (A53422)
2017 Ford F-550...
