JD 2025R Seat snapped off when removing backhoe
   / JD 2025R Seat snapped off when removing backhoe #1
JackieM
Tualatin, Oregon
None yet
OOOOPSIE! My first time removing the backhoe and I put too much pressure on the seat post when lowering the boom. Is this as easy a fix as i'm hoping it is???
   / JD 2025R Seat snapped off when removing backhoe #2
It's a bit hard to tell from the photo but it looks like 4 bolts hold the seat mount to the frame. Not sure how easy it will be to remove that piece since it looks like there may be another piece of metal in the way.
Once removed though you can either opt to replace the seat mount or possibly weld, though that mount might be cast..?? If it is steel, and not some sort of alloy, I would try welding first as well as reinforcing the joint with some steel welded onto the side of that mount to form a channel. Though not being able to see the other end of the seat mount it is hard to say how that might go.
Perhaps you could show us some more pictures and we may be of further help.
UNUSED RETRACTABLE AIR HOSE REEL (A54757)
UNUSED RETRACTABLE...
48" WIDE WOODEN W/ METAL RAILING (A54757)
48" WIDE WOODEN W/...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A52377)
2015 Ford F-350...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51692)
2013 International...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
