Branson 2515H heads to the shop for oil leak !!
   / Branson 2515H heads to the shop for oil leak !! #1
DGZRT
Stevens Point , Wisconsin
Branson 2515H
2020 Branson 2515H is going to the Dealer for an oil leak. I had the tractor warming up and I was going to hit the grease zerts underneath and there on the back axle was drips . Then I found droplets on top of the axle. I will up date when I hear what’s wrong .
I checked the dip stick and it was barely on the end but below the hash marks. When the tractor got warm the dripping stopped . I moved the one tree that was down and put the tractor away . Everything seemed to run perfect.
   / Branson 2515H heads to the shop for oil leak !! #2
Glad you caught it before something much worse happened! Let us know what they find.
Well good news the Tractor is back and working great . I have to give a big shoutout to Mike at Fox Valley Truck in Shawano Wi 👍👍 they went above and beyond to pick it up and get it done . Excellent Dealer and would recommend them to anyone . This was the response below .
   / Branson 2515H heads to the shop for oil leak !! #5
That is a great dealer , could have been a long stretch to get it back , splitting a tractor is a big job , I am very fortunate to have a great dealer in Daves Tractor in Red Bluff Ca . Good 4 u
That is a great dealer. Good decision!
Excellent Dealership. One of the reasons I chose them because they have multiple divisions and work on a lot of diesels. Not even a charge for picking it up and dropping it off . Anyone in that area of Wisconsin should check them out .
2022 KMC 5610 LOT NUMBER 212 (A53084)
2022 KMC 5610 LOT...
2017 Rogator RG1300B Dry Fertilizer Applicator (A53472)
2017 Rogator...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2016 Freightliner 114SD Tandem Axle Dump Truck, VIN # 1FVHG3DV7GHGW6796 (A51572)
2016 Freightliner...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2013 Doosan Light Tower (A51573)
2013 Doosan Light...
