Kubota L6060 Cabin Electric Outlet ?
   / Kubota L6060 Cabin Electric Outlet ? #1
speedyvelo
Black Hawk, CO
Kubota L6060
I have two outlets in the cabin: 1. cigarette lighter 2. A 4 pin outlet on the left side under the side window.
The outlet in the pics measures 1.5 cm from top to bottom and 1 cm width where the 2 pins are side by side.
Q1: is there a name for this type of outlet?
Q2 Where can I get the matching pair so I can use it to install a camera.
TIA, this site has been key teaching how to use the tractor initially with my first Kubota (B series) and then with the L6060.
-=terry=-
   / Kubota L6060 Cabin Electric Outlet ? #2
   / Kubota L6060 Cabin Electric Outlet ? #4
notaz3 Thank You! I've just placed the order​
-=terry=-
If it's not to late you might want to cancel order.
Just got finished trying to wire things up and, I have to retract my statement.
The clips work; however, when you go to wire them the prongs are opposite sides and don't connect. Ended up just splicing new connectors on the tractor side.
@notaz3 thank you again. To late to cancel but I can return it without problem. Or if I have a male/female 4 pins in the set I may end up replacing the original Kubota plug.​
-=terry=-
   / Kubota L6060 Cabin Electric Outlet ? #6
-=terry
That's what I ended up doing. Taking a male/female from the set and just replacing the original plug.
notaz3 Thanks Again. Kubota should have part number and description of the plug but...I could not find it in any place. Well not a big deal, I should have the camera connected soon. I believe the kit should be in the Post Office today.​
-=terry=-
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
2012 Mitsubishi Outlander Sport AWD SUV (A51694)
2012 Mitsubishi...
2013 Dodge Charger Sedan (A52377)
2013 Dodge Charger...
