Hydraulic transaxle leak in lawn mower.
   / Hydraulic transaxle leak in lawn mower. #1
turfranger
Member
John Deere 455 diesel
What is the thing to use to stop a leak on a hydraulic transaxle on a lawn mower?
   / Hydraulic transaxle leak in lawn mower. #2
The obvious answer is to replace the leaking seal. After disassembling my Craftsman garden tractor I learned that is not a viable option. There was no way to check fluid level just an opening to add fluid. I drilled a hole just below the seam joining the two halves and installed a hydraulic jack plug. I can now fill from the top until fluid runs out my check hole. I think I got the jack plugs from eBay. My Craftsman uses good old standard transmission gear oil so I just used the heaviest I could find - I think it was 85W-140 or something like that.
   / Hydraulic transaxle leak in lawn mower. #3
Assuming we are talking about the 455 in your avatar. the common leak locations are the O rings on right side for the forward and reverse direction control, And seal for the differential lock rod on left side will slide outward over time and cause a leak. And the third location is the gasket between the transaxle and the hydraulic pump/drive motor on the front of the transaxle. All three require removing the transaxle to get access to the leak locations.
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
CATERPILLAR CB24B SMOOTH DBL DRUM ROLhttps (A52705)
CATERPILLAR CB24B...
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A54313)
2012 INTERNATIONAL...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
