Ford 1710 hydraulic lift problem
   / Ford 1710 hydraulic lift problem #1
cedar21
Oak Harbor, Washington
New Holland TC 30
I am borrowing a Ford 1710 tractor, and the hydraulic lift operates backwards. When the control lever is pushed down, the arms raise, and when pushed up, the arms lower. What would cause this?
   / Ford 1710 hydraulic lift problem #2
If you're talking about the front loader that's the way they normally work, at least on the tractors I've used. If you're talking about the three point lever moving it forward usually lowers the arms while moving it to the rear raises them.
I am talking about the 3 point lift arms. Moving the lever down, or forward is raising the arms, and moving it up, or back, is lowering them, which is the opposite of how every tractor I have ever used has been. It can't be right.
   / Ford 1710 hydraulic lift problem #4
Someone has had the top cover off and didn't get the levers indexed correctly. Don't ask how I know. 🤬
Fortunately, I didn't have it completely assembled before testing. I had just replaced the seals (rings) on the lift piston.
Someone has had the top cover off and didn't get the levers indexed correctly. Don't ask how I know. 🤬 Fortunately, I didn't have it completely assembled before testing. I had just replaced the seals (rings) on the lift piston.
I figured it must be something like that. Thanks.
2025 JMR 40in Brush Grapple Skid Steer Attachment (A55851)
2025 JMR 40in...
2004 INTERNATIONAL PAYSTAR 5600I DAYCAB (A55745)
2004 INTERNATIONAL...
2001 Dodge Ram 1500 Pickup Truck (A55852)
2001 Dodge Ram...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55851)
2025 Kivel 48in...
2012 SCOTT MANUFACTURING  SAND CONVEYOR (A55745)
2012 SCOTT...
2018 Autocar ACX Xpeditor Garbage Truck (A55852)
2018 Autocar ACX...
