Mahindra 2638 leaking hydrolic fluid from the backhoe attachment
   / Mahindra 2638 leaking hydrolic fluid from the backhoe attachment #1
J_wolfe69
9Greatkids*
There is not a dealer around me to take this to so I need some help. My backhoe started leaking fluid at the bucket cylinder. It's not a hose but I think at the cap plug where the hose attaches. Do the caps unscrew? I don't want to put a wrench on it if they do not and make it worse. I suspect it's a ring that needs replaced in there. I'm not familiar with these things at all.
   / Mahindra 2638 leaking hydrolic fluid from the backhoe attachment #2
Cylinder needs rebuilt. I'd take it to a hydraulic shop and have it done as it appears that you lack the experience to do it and probably the tools as well.
   / Mahindra 2638 leaking hydrolic fluid from the backhoe attachment #3
Not sure what the "cap plug" is but where the hydraulic hose attaches to the cylinder is an inlet. It is usually a threaded fitting. You should be able to loosen and remove that fitting and apply some teflon tape to the threads and reattach. Be prepared to make a mess with hydraulic fluid so use a catch basin underneath. Also make sure the teflon tape is applied a thread or or two away from the end of the fitting.
I hope this helps!
I hope this helps!
The manuel I got for it calls it a cap plug but I think we are talking about the same thing. Machine only has about 100 hours but I'm pretty rough with it. Thanks for the insite !
2025 MAMMOTH SB-2 2025 SAND BOX TRAILER (A56129)
2025 MAMMOTH SB-2...
2008 Ford E-350 Versalift 29N 29ft Bucket Van (A55788)
2008 Ford E-350...
2019 FORD F250 XL EXTENDED CAB TRUCK (A51406)
2019 FORD F250 XL...
UNUSED WOLVERINE PT-16-01C 3P QUICK ATTACH (A54757)
UNUSED WOLVERINE...
UNUSED IRANCH IRMC HIGH END ELECTRIC MASSAGE CHAIR (A54757)
UNUSED IRANCH IRMC...
2016 Nissan Pathfinder SUV (A55758)
2016 Nissan...
