MF35 gas - valve adjustment
   / MF35 gas - valve adjustment #1
twosocks90
Blair, Nebraska
MF35 Utility (gas)
I took the fuel tank off my MF35 to (try to) repair a leak. Ouch, it gets expensive when gas is leaking out of there!
I see the valve covers are now accessible. Does the gas engine require periodic valve adjustment? If so, I might as well do it while the tank is out.
I checked the service manual that I have but somehow it only covers diesel engines. Go figure.
   / MF35 gas - valve adjustment #2
I don't feel like looking it up for you but take my word that the specs are out there if you search. IT manuals at Tractor Supply Company is one source of specs and a bunch of other handy stuff to know.
Your reply reminded me that I do in fact have an IT manual on the shelf! I totally forgot it was there.
It's .015 cold and .013 hot. I know what I'll be doing tonight...
   / MF35 gas - valve adjustment #4
Is that for intake and exhaust? Check and be sure that is for both intake AND exhaust. The ones you give sound good for exhaust. Usually intakes are a little tighter than exhaust. But, it may not be solid lifters, so there are just positive lock studs.
Yes, it's the same for both intake and exhaust.
How can I turn the engine? I would normally go for the crankshaft pulley but there's a shaft and hydraulic pump on the front of the tractor. There's no pulley bolt to put a socket on.
Looks like I have to spin the engine on the starter to get it positioned correctly. I checked #1 cylinder so far and clearance (cold) is .010 on both intake and exhaust, so they need adjustment.
This thread has a good description of the adjustment procedure.
   / MF35 gas - valve adjustment #7
Some have plate you take off to see teeth on flywheel.
   / MF35 gas - valve adjustment #8
You can stick a screwdriver in to catch the flywheel on the dizzy side. These machines (gassers) are low compression, you can also just spin the fan by hand, even easier with the plugs removed. As long as the belt is tight, anyway.
   / MF35 gas - valve adjustment #9
It does not hurt to do it while your in there ! & I would go ahead and do a valve job while your in there , & replace the valve stem seals , Also be careful with the rocker arm assembly when torquing it down very easy to break ! I have only done one valve adjustment to mine in 21 years , & I've owed the tractor for 26 , Model M-F 50 Z134 Continental engine ( 1959 )
   / MF35 gas - valve adjustment #10
As the valves recede into the head due to wear , the valve lash will tighten up to the point where the valves may not be able to seat . When I removed the cylinder head from my TO-35 ( gas) , I saw that the valves were very worn . I found a set of NOS valves online, and I hand seated the new valves into the head with lapping abrasive. I didn't want to have to reset the valve lash after the engine was run for a while, so I guessed that setting the lash at .002 inches wider than spec. would work. It did. And, since my factory gas tank was badly rusted near the battery, I "installed" a 6 gallon outboard motor fuel tank , which sits on top of the hood. I think I can now check the valve lash without removing anything except for the aluminum panel I installed down the center of the hood.
2012 KENWORTH T800 SLEEPER (A50854)
2012 KENWORTH T800...
2022 Chevrolet Tahoe FL SUV (A48082)
2022 Chevrolet...
2017 Nissan Juke SUV (A48082)
2017 Nissan Juke...
JCB 505-TC 4x4 Rough Terrain Telehandler (A49461)
JCB 505-TC 4x4...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
