Operating temperature for New Holland TN 70
   / Operating temperature for New Holland TN 70 #1
RW444
New Holland T70
Replacing temperature sensor for the fourth time. This time going with mechanical gauge.
Anyone know what normal operating temp. is for this tractor?
Thanks
   / Operating temperature for New Holland TN 70 #2
I have no information specific to your machine, but you can start with finding the thermostat opening settings and go from there.
For example, my tractor thermostat starts opening at 180f and is fully open at 203f. The manual declares the engine as overheating at 214f.
There also may be specs about the coolant sensor for your machine that may help. I've never looked into the sensors though.
   / Operating temperature for New Holland TN 70 #3
Thanks
The sensor is merely a temperature sensitive resistor that controls the current through the gauge. Generally, they either work or they don't, Why do you think the sensor is bad? What are the symptoms?
   / Operating temperature for New Holland TN 70 #4
Operating temperature should be somewhat below your thermostat rating. You would need access to the shop manual for recommended operating temperature.
   / Operating temperature for New Holland TN 70 #5
That's true about the sensor. The problem is that the sensor may not directly connect to the gauge in today's tractors. Instead, the tend to connect to the engine computer which uses the information in several ways and also sends a signal to a real or simulated gauge on the dash..
For more info on what happens, read what I wrote today about a similar problem.
   / Operating temperature for New Holland TN 70 #6
You make a good point. However, IIRC, the TN70 is not a common rail, electronically controlled engine. I believe it has a hydromechanical injector pump.
   / Operating temperature for New Holland TN 70 #7
Thanks. Yes, it's a possibility that checks all the right technical boxes. What I don't know is how the injection of your TN70 is configured. I wrote the post I pointed you to in the previous message to for a guy with an overheating JD5205 - which is made about in the years 2000 to 2007. I did so because his just mght have a hybrid system like on my 2008 model 310SG. The hybrid systems were common in the years about 1998 to 2012/14 - depending on HP and emissions Tier level. I don't know if any are being manufactured that way now.
Since yours is in that time period it might be a hybrid too. You might check to see if it has an "engine controller with a multi pin input.
I was sure that our own 2008 was individual mechanically controlled injectors. I mean it's easy to tell, right? Just pop the hood and look. The injectors don't have any wires, they do have high pressure tubes - one per cylinder - and all 4 of those tubes lead right back to the top of what is obviously the high pressure fuel pump. So it's a simple mechanical injection not a common rail and a non-computer type, right??
Well, so what is that black box I see bolted to the frame? Just a connection box? Why is it epoxied shut? I went down to shoot the breeze with the service manager and he says....Uh... it's not that simple.
I may have some details wrong, but the gist is that because in some hybrid systems used during those years it turns out that the fuel flow from the pump to the injectors IS able to be varied by that black box which sure enough is an engine computer - they just do it at the high pressure pump end instead of at the injectors. It's not so accurate and affects all the mechanical injectors the same, but it is a form a computer control, and yes, it does change the delivery fuel curve in response to what the computer sees as coolant temperature, barometric pressure, and a host of other factors.
So at one time it was possible to have an individual injector system, no common rail, and yet still have an a engine computer with the ability to modify fuel flow. BTW, it's programmable - but only by JD. Only they have the program and interface device to sync the engine computer to the ID# of each tractor. That costs extra.
rScotty
mechanics ain't quite what it used to be.
   / Operating temperature for New Holland TN 70 #8
rScotty
Mine is actually a 2007 TD95D and it's a Tier II engine. The only controllable function on it is an electro-mechanical timing reset on the Bosch IP that is controlled by coolant temperature. When the coolant temperature reaches 120F, the correct timing is restored. The TN series was made before then but I think it uses the same engine Iveco engines so it could have the same system. According to my manual, there is no PCM (power control module, i.e. computer) to control anything and I am so glad that this is the case. If the coolant sensor fails, the engine may run with a couple of degrees of timing "error" and I would suspect fuel usage will increase but it would most likely not effect starting except in really cold ambient conditions. I can't tell you how many offers we had on this tractor when we were selling our Montana ranch, mainly from big California operators who had Tier IV tractors.
   / Operating temperature for New Holland TN 70 #9
Mine is actually a 2007 TD95D and it's a Tier II engine. The only controllable function on it is an electro-mechanical timing reset on the Bosch IP that is controlled by coolant temperature. When the coolant temperature reaches 120F, the correct timing is restored. The TN series was made before then but I think it uses the same engine Iveco engines so it could have the same system. According to my manual, there is no PCM (power control module, i.e. computer) to control anything and I am so glad that this is the case. If the coolant sensor fails, the engine runs with a couple of degrees of timing "error" and I would suspect fuel usage will increase but it would most likely not effect starting except in really cold ambient conditions. I can't tell you how many offers we had on this tractor when we were selling our Montana ranch, mainly from big California operators who had Tier IV tractors.
Yes, that sounds like the same time frame as our JD310SG. I checked, and it is also Tier II. I do not know what the engine computer actually does on this 4045Turbo motor. It might be just timing, but from the hints I heard at the service dept. the computer also has some control over fuel. Unfortunately for us mechanical types, Deere has completely gone away from providing technical information on their tractors. That used to be their strong point.
But they must be doing something right with that approach. Their sales, stock price, and general popularity have never been this high. It's just not good for people who like to buy & maintain older equipment.
Sooo.... do you know enough on your TD95D to talk about the way timing and temperature is related on on the TD95D? I am curious how the timing is mapped to temperature? And if the coolant sensor fails - in what mode does it fail? Unlike old variable resistor type temperature sensors, the JD temperature sensor reports voltage to the controller. So an open sensor or broken wire is zero volts at the controller. The controller then interprets that is overheating..... but I don't now what direction it would change the timng. A JD secret....
rScotty
   / Operating temperature for New Holland TN 70 #10
rScotty
I don't have access to my service manual. However, I think it is binary; below a coolant temperature of 120°F, the timing is retarded 2°. Above a coolant temperature of 120°F, it is advanced by 2° back to design timing.
It is done internally to the hydromechanical Bosch Injection Pump. (As I said, I don't have access to the service manual. It's in our storage container since we moved to Idaho.) If I were designing the actuator I would have it fail to normal timing. 2° timing change is miniscule since I think this is just a "rule beater" to satisfy the EPA. during Tier II certification. I notice no difference in performance and the exhaust is invisible after startup.
   / Operating temperature for New Holland TN 70 #11
That's interesting about the "invisible exhaust" on your TD95D. I think you are saying it runs very clean. So does the old tier II motor on our JD310. Those Tier 2 engines only had to meet minor EPA standards at the time, but ours has a natually has clean exhaust - and it is very economical to run in spite of it being 90 hp.
It makes quite a contrast to our 2008 Kubota with the emission equipment designed for the Interim Tier 4 regs - which are NOT the same as the final Tier 4 regs. Nobody would call that exhaust invisible. It's black. Interim Regs were all about NOx & not about soot.
That engine has horrid exhaust & less HP than the JD but uses twice the fuel. Getting a whiff of its exhaust will make your eyes cross, but that is what the EPA standards required at the time. Still, it's been a reliable engine in spite of the dirty exhaust
Someday I'd like to find a way to study up on exactly what the "engine computer" does on our Tier 2 JD.
rScotty
   / Operating temperature for New Holland TN 70 #12
rScotty
Unless you know somebody that worked on designing the engine controls who is willing to talk about their design, I'm afraid that stuff is considered proprietary to the engine company. However, there are some books that discuss common rail fuel systems around. Look at Alibris or Amazon, etc. for books on this subject.
One of the methods to deal with NOX in gas turbine engines was "lean burn, quick quench". Combustion chemistry is a very complex subject. The primary burning zone is air rich and the secondary burning zone is fuel rich. As I understand the principle, the lean burn generates a great deal of NOX due to high temperatures and high airflows. The quick quench zone brings in fuel to quench the tempertures and reduce the NOX. Maybe Kubota used that technology in your interim Tier IV engine. Being able to control multiple parameters based on sensor info is the reason for electronic Power Control Modules (PCM).Granted, a gas turbine is a different beast from a compression ignition engine but the mechanism for the production of NOX is the high gas temperatures so injection timing and fueling rate using a computer controlled common rail system with multiple sensors maybe the way it is done. I'm just theorizing since I have no experience with CI engine control systems. I just know the old hydro controls are the most reliable ones.
   / Operating temperature for New Holland TN 70 #13
Thanks
I have the manual for cab version of that tractor(TN70da). It’s the same engine. The green range on the factory gage relates to
140 -230 F. See the pics
500BBL WHEELED...
2023 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A60429)
2023 CATERPILLAR...
2014 Dodge Grand Caravan Van (A59231)
2014 Dodge Grand...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A56438)
Gleaner N630 Corn...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
2017 JOHN DEERE 310SL BACKHOE (A60429)
2017 JOHN DEERE...
