Oil change on ford injection pump
   / Oil change on ford injection pump #1
Brady D
Southern Middle Tennessee
Ford 1910, Case farmall 95, John Deere 317g
I have a ford 1910 and I had heard about changing the oil in the injection pump I had no idea that was a thing any advice
   / Oil change on ford injection pump #2
There’s a ton of information on the web..
Kiki made 2 versions of that pump..
1 w drain and full screws.
(1above the other)
1 w/o.
The oil amount is 5oz.
U can add oil thru the top of the governor..
The pump body has an overflow pipe on the back of it.. any excess will flow out of the pipe while running..
Or
U can loosen the screws on the governor cover and pry back on it..DO NOT TAKE IT OFF.!! There are springs and shims that will get lost..
Be careful prying it back.. there is a gasket that seals that area..
Do a search and you’ll find a pic of the drain and full screws.
(1above the other)
1 w/o.
Or
Thanks for the help I appreciate it
2013 PETERBILT 388 DAYCAB BOBTAIL VACUUM TRUCK (A53843)
2013 PETERBILT 388...
2008 PETERBILT 367 HOT OIL UNIT (A53843)
2008 PETERBILT 367...
2017 HITACHI ZX350LC EXCAVATOR (A54607)
2017 HITACHI...
2004 INTERNATIONAL 4300 BOX TRUCK (A54607)
2004 INTERNATIONAL...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2018 KENWORTH W900 DAY CAB (A53843)
2018 KENWORTH W900...
