I had no idea how easy plastic welding is
   / I had no idea how easy plastic welding is #1
MinnesotaEric
Super Member
Nevis, MN
Kioti NX6010
I got a plastic welding kit and repaired a fuel jug (akin to a giant milk carton) successfully which prepared me for my most important plastic repair to date! follow me.
   / I had no idea how easy plastic welding is #2
You learn that trade real quick when you race motocross bikes and always have broken plastic, LOL
I got lucky when I raced moto and mostly didn't crash so I missed out. When I took up road-style racing with 31 broken bones from when I was younger, I was old enough to have a rule of not crashing and became the guy to show others how fast their junk could run safely.
But my AMA-engined Husky 510, with 50honest hp at the rear wheel on an Eddie Current type dyno remains my favorite track toy.
   / I had no idea how easy plastic welding is #4
I didn't use anything as advanced as an actual plastic welding kit. I always just used an electric soldering gun and if it was really bad, some pieces of scrap plastic as filler.
But I guess you'd want to use something better if you were doing tanks like that.
I only had to fix rad shrouds and fender cracks.
Saves you a lot of money.
I always liked Supermoto bikes. That Husky is cool. I never did pavement. Just motocross when I was young on Yamaha then Honda 80's and 125's, then switched to AMA District 14 enduro and hare scrambles on CR250's and a CRE500 then quit in 2003 on a KTM 300EXC. Now I just bought a Beta 430 RR race edition. My daughter calls it my mid life crisis bike, LOL Also found out I'm not the same rider I was in 2003, LOL
But it is a good way to get some exercise again.
   / I had no idea how easy plastic welding is #5
JB epoxy worked wonders on a plastic 5 gallon diesel can I punctured with my grapple.
A buddy who continues to run enduros and hair scrambles in the Paul Bunyan popped over one day on one of his KTM's. Apparently, it has a clutch in it something like the first Honda Big Red ATVs. You can select gears, but you cannot stall the machine. You can even clutch up wheelies. I marveled. If only I had that clutch when I ran in the woods.
Husky-wise, I still have that bike with plans to hang it upside down from a vaulted ceiling someday. It is the last of the flat slides. Everything else is fuel injected. It also is a bit of a unicorn since Husky was Italian-owned back then so I believe getting parts for it would be super hard. Anyway, for now it is in barn-bike-mode.
   / I had no idea how easy plastic welding is #7
The plastic valve housing on my pool pump is cracked, and a replacement is $650. I was just wondering the other day if i could somehow weld it instead of replacing the damned thing.
   / I had no idea how easy plastic welding is #8
It is likely a Rekluse clutch Eric. Lots of people are running them now. You are right, everything is going fuel injected now. It's starting to even get hard to find a carb'd two stroke now.
I have mixed feelings about it. They run great and you don't have to play with jetting, but now you have electronics, check engine lights and need a dealer scanner to do anything.
My Beta has an adapter cable to plug in with a standard OBD-II scanner, but it only allows you to read the codes, you can't cancel or reset anything with it.
I think you can so long as a sealed, hairline crack isn't going to bother anything. Take a look at my video and decide for yourself.
Repairing things wise, that is the biggest hassle I have (apart from not having a shop, or heated garage): ECUs behind paywalls.
Year: 2009 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 Door C... (A55788)
Year: 2009 Make...
2019 BOBCAT E50 EXCAVATOR (A52705)
2019 BOBCAT E50...
2008 Ford F-550 4x4 Dump Truck with Lift Gate (A53422)
2008 Ford F-550...
2018 JLG 2632ES 26ft Electric Scissor Lift (A55787)
2018 JLG 2632ES...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A54757)
UNUSED WOLVERINE...
2021 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2021 PRINOTH...
