Kioti dk 5010 Hydraulic leak at shift lever boot? Clutch drive
   / Kioti dk 5010 Hydraulic leak at shift lever boot? Clutch drive #1
Sjj123
Kioti DK 5010
So I've taken off 100 bolts to raise the platform to get to the shifting boot (1-4 gears) behind the gas tank. Can anyone help with a parts diagram or likely explanation as to what has deteriorated. I believe I understand that the boot is a dust cover and if leaking at this location a seal of some sort has failed?
Sj
NY
Wel...I learned that the shift boots are part # T-5715-21383 (same part for right and left),,,,leakage through the shifter can be tempered with Permatics Black Ultra Silicone
and a serial number starting w/ P = 2014 model
The amount of stuff one has to take off to reach the right shift lever boot is over the top
   / Kioti dk 5010 Hydraulic leak at shift lever boot? Clutch drive #3
My dk5510 leaking as well. Traced leak to what I believe is the source, the shifter boot. I just went through the painful process of removing and it’s definitely shot. Curious if replacing this part resolved your issue?
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2016 Toyota Prius Hatchback (A53424)
2016 Toyota Prius...
VERMEER NAVIGATOR 53 D23X30111 DRILL (A51406)
VERMEER NAVIGATOR...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
JOHN DEERE 4066R (A53084)
JOHN DEERE 4066R...
